no power
Old Sep 18, 2019 | 06:06 PM
hvnguyen's Avatar
hvnguyen is infamous around these parts
no power
what happen ? i have no power, no light , nothing on dash board after i jump start my 2010 porschs pana .
any idea ? please help...
Old Sep 18, 2019 | 09:24 PM
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
Sounds like you may need a new battery. Was it running fine until this happened? What caused the need to jump start it!?
Old Sep 18, 2019 | 09:41 PM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
I hope you didn't reverse the polarity!? (Gulp)...
Old Sep 20, 2019 | 07:44 AM
hvnguyen's Avatar
2010 panamera ( no power)
no, but the ignition was on the accessory position when i connect the jump cale...
Old Sep 20, 2019 | 07:55 AM
hvnguyen's Avatar
she was fine it happen after 3 months i was out of town. forgot to hook up batt. maintenance....
Old Sep 20, 2019 | 09:11 AM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
have you checked your fuses?
Old Sep 20, 2019 | 10:23 AM
jzchen's Avatar
5 Year Member
So:
Jump start
3 months working fine
Left unattended
Dead upon return
I'd suspect dead battery as well...
From reading about replacement you can get any battery of the correct size, but just change the serial number one digit when registering....
Old Sep 20, 2019 | 02:07 PM
DogWood's Avatar
5 Year Member
also note that the battery doesn't have to be dead to still be an issue, when it was drained all the way down it was most likely damaged, these cars are very sensitive to voltage levels and current
Old Sep 20, 2019 | 07:06 PM
ciaka's Avatar
Dogwood right. Drive to autozone, ask them to do load test on batt. Also check stocker on batt (when it was made). More 4th han 4 years, start doubting it.
Merlin
Apr 11, 2012 07:57 AM
drop997stop
Mar 10, 2007 06:08 PM
Kvic
Dec 22, 2006 01:36 PM
