DIY: 970 PDK Transmission Mount Replacement
Old Mar 8, 2022 | 12:56 PM
ja0's Avatar
ja0
ja0 is infamous around these parts
Originally Posted by DogWood
Trans Bracket to trans 65Nm (48ftlb) (3 bolts under the bracket)
trans support to bracket 23 Nm (17 ftlb) (2 bolts that attach bracket to 2 bushings
trans support to bracket 120 Nm (89 ftlb) ( 1 bolt in the center)
trans support to body 65 Nm (48 ftlb) (6 bolts bracket to body)
Thank you very much!
Old May 27, 2022 | 07:41 AM
CrossT's Avatar
CrossT is infamous around these parts
Did you (or anyone) by chance replace engine mounts on the 970 with the updated ones? I have to sort out whether there is a requirement to replace the subframe when you replace the mounts. Getting conflicting information from dealer and others. It’s a $2,500 subframe, so not trivial for the pocketbook!
Thx
todd
2010 PTT
1999 996 C2 Cab
Old May 27, 2022 | 08:44 AM
ciaka's Avatar
I've never heard of require to replace subframe as maintenance only. I'd ask for technical reasoning or call it bs.
Old May 27, 2022 | 09:51 AM
CrossT's Avatar
My thoughts also. It makes no sense
Thx
todd
2010 PTT
1999 996 C2 Cab
Old Nov 29, 2023 | 07:42 PM
vkb123's Avatar
5 Year Member
vkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond repute
Thanks for posting this @DogWood! Changed my transmission mount today while doing the PDK service. Really appreciate you posting this!
Old Mar 25, 2024 | 10:19 AM
rheidtman's Avatar
rheidtman is infamous around these parts
I located these new, improved MOOG sway bar links P/N K750805 (for PDCC suspension) that have larger bushing area, as well as being polyurethane. My OEM versions were in the process of separation. They also have a Zerk fitting for future lubing - novel idea (yet, quite old indeed!)
quick968
Aug 2, 2022 08:37 PM
Ronny-
Nov 26, 2015 11:04 PM
rennwerkes
May 13, 2012 09:32 PM
Valley996TT
Sep 10, 2011 05:19 PM
white out
Lamborghini
Apr 10, 2011 01:44 AM
