Coolant leak / P2186
Old Dec 2, 2019 | 09:26 AM
970's Avatar
970
970 is infamous around these parts
Unhappy Coolant leak / P2186
Hi all,
long time lurker. Never felt I had much value to add but sure did learn a lot. Seeing how my 2010 970 4S has been keeping me very much on my toes and in the shop I hope I may have some tidbits of knowledge to share soon on an extensive 6 month labour of 'love'.
For now, just more questions and frustrations sadly.
Road trip planned, so send it in for servicing/checkup. Picked it up the night before from the stealership after an oil/filter change, PIWIS coolant bleed (due to recent radiator replacement), PDK oil change etc etc. All checked out and good to go. Not 15 miles later, massive coolant leak. Onto flatbed back to the shop. Of course feared the worst but it was "only" the vent line that sits under the intake manifold. Must have popped due to the bleed. Got quoted 3k to do the vent line and upgrade the housing with the bolded pipes. Pass for now, thanks.
Replaced the vent line, filled and bled the coolant system, drove it slowly and kept eye on temperatures non stop, all good. Until about 50 miles later when I noticed that my oil temperature started fluctuating. Jumping all over the place in very rapid swings. From 195 to 160, back to 200. Very erratic and a far cry from the normal and always constant 212/219 which it now hardly touches. Must be some special oil they put in! Yet the coolant temp does not move from 194 once warmed up. Lock solid, thank fully.
The code I get is P2186, which comes up as a "engine coolant temp sensor, radiator output implausible signal" which has me stumped. Yes, the coolant leak could explain that but what does my coolant sensor have to do with the oil temp? Replaced the sensor on the radiator, no change. There's another one hiding in the back behind cyl number 8 which I'd rather avoid right now as taking the manifold off twice in a week is pushing me to my limit. Then again, having seen the carbon caked state of my valves....sigh
Any ideas anyone?
TIA
Alex
Old Dec 2, 2019 | 11:55 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Originally Posted by 970
Hi all,
Any ideas anyone?
TIA
Alex
Make sure the coolant temp sensor nearest the radiator is properly connected. If it is it may have gone bad. (Sorry, just a hunch just got ours July and so many issues I'm looking forward to trading it in already)....
Old Dec 2, 2019 | 01:00 PM
970's Avatar
970
Thanks but I replaced that one today with a new one. No difference.
Old Dec 3, 2019 | 05:06 AM
970's Avatar
970
Ended up that the sensor was fine but that circulation was not. So though coolant temp gauge read proper 195, this reading was likely from the engine block coolant sensor. A quick touch of the hose on the drivers side showed that it was much cooler than the one on the passengers side. (perhaps I should have thought of that before changing the sensor twice, the good old, touch to verify!). Oil temps holding steadier also, likely DME was getting confused.
Changed thermostat and water pump today.
Now that this seems cleared, immediately started to get the dreaded P1023 again. Short lived joy.
gh0stman
Cayenne 955/957
Jan 13, 2015 03:02 AM
acelucas
Jun 25, 2013 08:44 PM
crazyed71
Oct 4, 2011 06:01 PM
Pmafia
Aug 5, 2011 09:01 AM
82targa
Jul 22, 2008 07:44 PM
