970 GTS addtional air intake flaps open
Old Apr 16, 2020 | 12:17 PM
XDZZ's Avatar
XDZZ is infamous around these parts
I noticed that the additional air intake flaps are always open, I read it online that it should only be open when the engine speed reaches 3500rpm. Anyone know why & how to resolve this?
Old Apr 16, 2020 | 06:26 PM
970gts's Avatar
5 Year Member
970gts is infamous around these parts
I think they are vacuum actuated. Check to see if the hoses are disconnected or broken. Can try to spray some lubricant on the hinges too.
Old Apr 17, 2020 | 10:58 AM
XDZZ's Avatar
Thanks 970gts. I just changed cylinder 6 ignition coil. In order to get more space, I disconnect the part (no idea what it is for) which shows in picture red circel. After change, I forget to reconnect it and start engine (connected now). Now I can feel slight vibrition, rpm is slight fluctated at idle and flaps oped. Not sure why.
Old Apr 18, 2020 | 11:16 AM
970gts's Avatar
5 Year Member
Reconnecting a part that should be connected is always a good thing. As you noted originally, at idle the flaps should be closed. Can you get your fingers or screwdriver through the grill and see if the flaps move freely when the engine is off (there will be a bit resistance because the flaps are spring-loaded). A little bit of lubricant on the hinges can't hurt. Check for loose/broken vacuum lines again.
Old Apr 19, 2020 | 08:40 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Is there a reason to want/keep them closed until high RPM? Isn’t the more air made available by three filters better than the one central one? Sounds like a good modification for me to go the other way.
If it helps any, when I was having the rough idle/almost stalling issue the round circled thing pops up as the engine self revved itself to stave off stalling.
Old Apr 20, 2020 | 02:47 PM
riden's Avatar
riden has a spectacular aura aboutriden has a spectacular aura aboutriden has a spectacular aura about
You would certainly want the flap closed when parked to keep the critters out. There may also be a higher probability of water intrusion if open during steady state operations.
Old Apr 22, 2020 | 06:47 PM
jzchen's Avatar
5 Year Member
Thank you! Those are great points I didn't originally consider.
Just A GTS
Nov 20, 2016 08:40 AM
rokkoutaishi
Nov 18, 2010 08:47 AM
Dragon911TT
Mar 26, 2008 08:55 PM
Tim W.
Oct 7, 2004 10:55 AM
