Battery Charger for ECU Flash
Old Apr 29, 2020 | 11:48 AM
tallpaul's Avatar
tallpaul is infamous around these parts
Anyone who has done the My Genius based ECU flashes with an early 970 - did you need to put the car on the charger due to how long it took to read and re-flash the ECU? IF so, which charger did you use? Figured I'd see if there was any preferred models others are using or if it was even necessary.
Old Apr 29, 2020 | 01:07 PM
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
When I did my 2010, I did not use any type of charger. I had challenges w/ my ECU reading the My Genius unit and eventually tossed in the towel and sent in my ECU for them to program. Bottom line is I spent an excessive amount of time w/ multiple attempts going thru the My Genius process and it never affected other electrical systems. The flash I used made a significant difference in drivability and eliminated the turbo lag. Best of luck!
Old Apr 29, 2020 | 04:47 PM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Perusing the Porsche technical information I thought I saw 40A or higher as the recommended power level.
Old Apr 30, 2020 | 02:49 PM
tallpaul's Avatar
Well if anyone else has this question I'm not sure it was even necessary. Borrowed someone's 12A/75A. But it only took 1 minute to read and maybe 10 minutes to write the file. Not sure it even took long enough for a regularly driven cars battery to get low. But probably liability for the company and insurance from smoking an ECU for you.
Also, love the tune. This is definitely a no brainer on these cars... other than my already terrible gas mileage and high tear wear will likely only get worse....
Old May 2, 2020 | 01:58 AM
jzchen's Avatar
5 Year Member
That 12A/75A was probably enough to save you from what skiracer13 went through.
michaeldantep
Apr 29, 2013 01:16 AM
Tigerbite84
Apr 13, 2013 02:33 AM
silver
Jul 26, 2011 06:45 PM
mass
Nov 30, 2009 11:21 AM
jalmood
Mar 21, 2009 12:43 PM
