Steering rack bushing
Old Jul 21, 2020 | 08:33 AM
rog2961's Avatar
rog2961 is infamous around these parts
Looking to get rid of some shimmy in the steering under braking. Was going to do inner, outers and rack bushing but doesnt look like porsche sells seprately. Is only option to get new rack?
Old Jul 21, 2020 | 08:56 AM
dbishop1113's Avatar
dbishop1113 has a spectacular aura aboutdbishop1113 has a spectacular aura about
I am new to panamera but have 14 years professional automotive repair experience, typically shimming under braking is warped rotors, Id verify loose steering components before replacing
Old Jul 21, 2020 | 09:37 AM
rog2961's Avatar
Rotors, upper and lower bushings are new. Was hoping i could just swap out the bushings since i was getting a alignment anyways
Old Mar 2, 2021 | 02:14 AM
970's Avatar
970
970 is infamous around these parts
Hi Rog, did you ever find the bushings?
Old Mar 2, 2021 | 04:51 AM
rog2961's Avatar
Nope, only way to get them is to make some poly ones
Old Mar 4, 2021 | 12:18 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
If it helps any, there seem to be somewhat cheaper alternatives to buying a Porsche genuine steering rack:
Saw one left at Rock Auto. Saw it also at AutoZone.com.
(I got my upper control arm from AutoZone when I replaced the original with ~ 48k mi. Stopped the crunching noise on compression so far. Why would I do such a thing? If I ever need to replace it again I won't need to pay for the replacement arm. If we keep the car long term that is)....
Old Jul 16, 2021 | 11:42 AM
Ntk974's Avatar
Ntk974 is infamous around these parts
hello.
do you know what is the dimensions of these bushing ?
Old Sep 24, 2022 | 04:36 AM
rog2961's Avatar
Another alternative to this is to fill the rack bushings with window weld. Pretty much will stop the moving.
Old Sep 25, 2022 | 02:45 PM
rog2961's Avatar
I replaced all of my front end including two shocks and was getting terrible inner wear on my tires. Car would follow ruts and crowns in the road no matter how many alignments o got. Ran through two sets before I narrowed it down to the rack. If you have someone look while rocking back and forth, the rack moves a couple inches. Since no one sells the bushings I tried injecting them with 3m window weld. If I have to buy a new rack I have nothing to lose anyways. On day 1 of cure will see if it fixes my problem. I tried moving the bushing with a screwdriver and it's already moving way less.
Old Sep 26, 2022 | 06:12 AM
rog2961's Avatar
Happy to report there is no movement on the rack bushings filled with window weld. Just be sure to let it cure 2 days. Fixed issues with my car losing alignment right away. Lots of guys use these to fill engine mounts so worth a shot if you don't want to get a new rack for 2 bushings.
Old Feb 20, 2023 | 12:52 PM
rog2961's Avatar
This didn't work at all. Ended up finding some bushings from Poland if anyone needs them. I ordered and installed them and they work great. https://turboworks.pl/product-eng-77...-970-2PCs.html
If it's in stock only takes 4 days shipping from Poland so it's quick too.
Old Feb 25, 2023 | 06:40 AM
riden's Avatar
riden has a spectacular aura aboutriden has a spectacular aura aboutriden has a spectacular aura about
Nice find. Not sure about the currency conversion. Did you purchase with a credit card or use PayPal?
Old Mar 11, 2023 | 10:37 AM
jzchen's Avatar
5 Year Member
Thank you very much for sharing this find! I could not successfully find any.
Old Jun 7, 2023 | 09:15 AM
allro's Avatar
allro is infamous around these parts
Thanks ordered in poland
Old Nov 28, 2023 | 02:59 PM
NineSeventyTT's Avatar
NineSeventyTT is infamous around these parts
+1 for the bushings from Poland. They were backordered for about a month when I ordered, but did ship in less than a week when they became available. Cost me $106 shipped. Did not come with screws.
For anyone interested, I was able to do the install from underneath the car while it was up on ramps. Took me about 3 hours.
Consider lubricating or replacing sway bar bushings while you're at it, as they will be fully uncovered by this process.
  1. Remove belly pan and center crossmember (8x bolts) (16&18mm).
  2. Remove steering rack screws & nuts (2x18mm). You will need to access nut above rack. Passenger side is easy with wrench perpendicular to steering rack, driver's side access is difficult but can be done with wrench parallel to rack, coming from center of car.
  3. Remove 2x steering line supports from rack, both sides, with 10mm nut on stud.
  4. Remove 4x torx screws from swaybar bushing heat shields to allow shields to move and bend out of the way.
  5. Pull steering rack forward until the metal spacers in the middle of the old bushings are accessible on both sides.
  6. Use bottle jack or other to press metal spacers out from middle of old bushings, tearing rubber. You can use a hammer and small flat head screw driver to help separate metal spacer from the rubber, minimizing forces required when you press.
  7. Pull steering rack fully out of mounts, you should be able to move it fully out and pull it down, it's a tight fit to get past the lip on the driver's side.
  8. Use jigsaw, sawzall, file, oscillating multitool, or other, to slit old bushing sleeves from inside. Pull out lower bushing and then push out upper bushing. CUT TOWARD THE BODY OF THE RACK, NOT A THIN WALL, IN CASE YOU CUT INTO BUSHING BORE SLIGHTLY, YOU DON'T WANT TO WEAKEN YOUR RACK.
  9. Install new bushings into rack from both sides. Use Lubricant.
  10. Tap new spacer into lower bushing until it starts to push upper bushing out.
  11. Use old nut+bolt, and large washer that ships with bushings to push spacer into upper bushing, then remove nut, bolt, washer.
  12. Push rack back into alignment, it's difficult to get the driver's side back in. Try rotating the rack to assist.
  13. Secure with NEW bolt and nut. Again, driver's side access is difficult but it is possible to get a wrench in there to access the nut.
  14. Assemble in reverse, enjoy!
Steering Rack Bolt - 9A7-008-209-00
Steering Rack Nut - 999-084-445-01
Lastly, I took some measurements of the bushings and spacers. It's difficult to measure flexible parts accurately, but my best attempts are:
Bushing (4x):
Material: 85 SHA Polyurethane
ID - 24.9mm
OD - 38.5mm
Overall Lg - 24.75mm
Flange Dia - 50.5mm
Flange Thk - 4mm
Spacer (2x):
Material: Nickel Coated Steel (originals were aluminum, so steel should not be critical)
OD: 25.1mm
LG: 56.15mm
mercedesc63
Apr 29, 2020 11:44 PM
Okie996
May 11, 2015 01:28 AM
racerjsz
Aug 27, 2006 08:22 AM
