PDK transmission error codes and wont go into gear
Old Sep 23, 2024 | 06:45 PM
ciaka's Avatar
Do you have history on the tranny? Oil change history, ormther repairs, etc. No history other than oil change would support shift sensors if assisted by codes.
What error codes do you get?
are they same as ones I was getting?
dealer will tell u to replace transmission as they can charge you 30 or 40k for new one or 20k for used.plus labor.
​once does not drive, how does it get fixed to drive?.
if your codes ar3 same, it's the shift sensors, if no grinding or bad noises, car just cannot drive, then it's shift sensors even more.
Old Sep 24, 2024 | 01:09 AM
Marc13190's Avatar
Marc13190 is infamous around these parts
Yes it's important to have dtc codes.
No problem it's possible to repair PDK gearbox.
Old Oct 17, 2024 | 07:40 PM
hkb5variant's Avatar
hkb5variant has a spectacular aura abouthkb5variant has a spectacular aura abouthkb5variant has a spectacular aura about
Someone has fixed the same issue by replacing the PDK module only. https://www.ebay.com/itm/355956390191]this is an easy fix
Paul970
Oct 10, 2019 07:31 PM
Claudio66
Apr 4, 2016 09:01 PM
iPhoneEngineer
Apr 24, 2012 05:59 PM
doug2255
Jan 23, 2010 08:46 AM
