Help with errors and codes
Old Oct 16, 2021 | 10:30 PM
  #31
gvenz33's Avatar
gvenz33 is infamous around these parts
Originally Posted by jzchen
It's possible. So there are no codes in your PIWIS? I just fixed mine by activating Windows 8 Pro (both boot drives) with valid codes then upgrading to Windows 10 Pro. Then made a clone/backup. Both have "Fault Finding" shaded out (just checked a few moments ago) so I'm afraid I'm not going to be helpful looking it up. But yes Google the C1200C and someone shared what looked like PIWIS fault finding. One of the solutions was reflash/program the ECU...
An update. It's October and slight closer t to resolving this issue. The EC you was replaced but also found out that the compressor was also malfunctioning. Replace the compressor but the aftermarket compressors seem to overheat will quickly. Right now the front end is slammed to the ground and the compressor it's not responding. So the compressor is not responding, the front end is slammed, but the back and it's still raised.
Question I have is can the compressor be rebuilt? Or does anyone know where to find the compressor that is compatible with my 2011 Porsche Panamera 4S? These are the labels to my original compressor.
Old Oct 17, 2021 | 07:18 PM
  #32
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
I think the valve blocks go bad, which may be your problem.
FCP Euro has the pump but seems a little expensive:
https://www.fcpeuro.com/Porsche-part...b=8&d=15908&v=
PanameraTrout
Mar 16, 2021 01:50 PM
nickmantra
Jun 23, 2019 07:47 PM
Tony Fowler
Oct 12, 2018 07:59 AM
ttt408
Jul 13, 2015 01:32 PM
mun802
Sep 17, 2011 07:43 AM
