Seat heater/cooler issue
Old Oct 17, 2021 | 09:41 PM
PapaB's Avatar
PapaB is infamous around these parts
My driver’s side seat cooler and heater wont stay on. Whenever I push either button all three LEDs light up but then immediately go out. Curious if anybody has experienced this issue, or have any thoughts on what it could be?
https://youtube.com/shorts/aCjycVBIjJI?feature=share
Old Oct 25, 2021 | 06:35 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Try to take a peek under the seat for some loose connector or chaffed wiring?
Old Oct 26, 2021 | 09:59 PM
PapaB's Avatar
Thanks for the suggestion! Took a peak from front and rear and everything looks fine and snug. Maybe a fuse (that’s next on the list to check)?
Old Oct 29, 2021 | 01:20 PM
pwc6t3's Avatar
pwc6t3 is infamous around these parts
Turn your engine on, check the voltage on the dash, push the heated seat button once and watch the voltage and check the drop. It could be that your battery doesn't have the power to do it, so it turns it off in a safety mode, sort of like the auto stop/start button. Just a thought.
Old Oct 30, 2021 | 06:15 AM
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
If the car's voltage drops a lot when the engine is running and the seat heater is flipped on, the problem isn't the battery. It's the alternator. Once the car is running, the battery is really on there to be recharged. Pretty much it's sole purpose is to start the car.
Randy V
Bentley
10
Mar 5, 2025 10:06 AM
randyb
Jan 31, 2017 10:20 AM
996flyer
Jan 19, 2010 12:36 PM
drhenrock
Sep 2, 2009 09:23 PM
