Seat Memory Stopped Working
Old Feb 24, 2021 | 10:22 AM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
Haven't done anything that should have impacted this. I can no longer save seat settings or retrieve them using the seating memory buttons. The seat adjustments do operate normally.
Any suggestions?
Thanks.
Old Feb 27, 2021 | 02:35 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
Recalibrate them in the same way you'd do the windows, Move the drivers seat max forward and hold the button in for about 5 seconds. repeat this all the way backwards, then the same with the backrest. You'll find they remember their settings again now, and your memory will work again.
EDIT: Do the same with the steering column.
Old Feb 28, 2021 | 01:57 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
Interesting, thanks. I'll give this a try as well as my seat memory doesn't
I won't hold out many hopes though as I did a full scan on my car yesterday:
01903 - Seat Tilt Adjustment Motor (V231)
005 - No or Incorrect Basic Setting / Adaptation
No idea what that means
C
Old Mar 2, 2021 | 10:25 AM
CatmanV2's Avatar
5 Year Member
Now I know what it means
With a borrowed copy of VCDS cycled through all the activations and now everything appears to work as it should
I *think* you have to do it on all of them. But certainly it wasn't going all the way forward on command, so I had to manually intervene as well.
C
Old Mar 7, 2021 | 02:59 PM
kongolo's Avatar
5 Year Member
kongolo is infamous around these parts
Seem to be having the same problem with the seat memory. How exactly did you fix it?
Old Mar 8, 2021 | 12:16 AM
CatmanV2's Avatar
5 Year Member
I used VCDS to run through the sequential output operations. I think you can do it manually as well: Move the seat to the full extent of all its adjustment. So all the way forward, back up, down, etc etc.
Let us know if that works?
C
Old Sep 9, 2021 | 12:24 PM
Randy V's Avatar
5 Year Member
Sorry AJ - thought for sure I posted a follow up on this one.
Anyway your suggested fix worked a treat. Much thanks sir.
Old Aug 3, 2022 | 06:34 AM
ST500's Avatar
ST500 is infamous around these parts
Thank You!
Noticed the memory seat on the driver's side did not work. Manually recalibrated like you mentioned (before digging VCDS out) and it worked straight away! All the previous presents were saved so didn't have to re-do them. Thanks @AJ1 !
Old Aug 3, 2022 | 05:07 PM
AJ1's Avatar
AJ1
5 Year Member
You’re welcome.
Old May 16, 2024 | 09:10 PM
BentleyF's Avatar
BentleyF is infamous around these parts
worked on mine as well my seat had lost it memory settings and also when moving the seat forward to get in back seat the button under handle (forward and back arrows)did not work. after resetting everything worked fine. this is on a bentley gt speed 2016.
Old Mar 5, 2025 | 10:06 AM
Filippo79's Avatar
Filippo79 is infamous around these parts
worked on mine too!!!! fantastic forum!
rohnin
May 19, 2022 05:01 PM
randyb
Jan 31, 2017 10:20 AM
randyb
Aug 10, 2016 04:08 PM
strat10
Feb 3, 2011 12:47 PM
