PCM/Burnmester Audio Problem
Old Jan 14, 2022 | 09:00 AM
tallpaul's Avatar
tallpaul is infamous around these parts
My audio in my 2011 PTT stopped working a few weeks ago. No sound from radio, phone or NAV. Checked PCM fuses, reset PCM, cleared codes and pulled and reseated the AMP in the floor board. Before I go and buy a replacement AMP, anyone have a wiring diagram or know how to test to confirm the issue? Is the A3 fuse in the trunk the fuse for the AMP?
I did confirm the optical cable appears to be on but the amp FAN is not spinning. The PCM system works fine otherwise, just no audio. Seems like the AMP but wanted to be sure. Also, for anyone who swapped it out did it require coding?
Old Jan 15, 2022 | 01:35 PM
ScottDy's Avatar
ScottDy is infamous around these parts
Check to make sure your audio source is not set to Aux
Old Jan 15, 2022 | 02:03 PM
tallpaul's Avatar
Yes the problem exists across all sources AM-FM-Aux-Bluetooth-Sat
al10vilk
Cayenne
Jun 29, 2023 08:15 PM
Ryanm51981
Oct 7, 2012 02:17 PM
Car-Narcissist
Feb 13, 2011 06:16 PM
fjpgt3
Feb 6, 2009 10:18 PM
