Can we switch tires from left to right?
Old Aug 7, 2022 | 10:16 AM
Quang's Avatar
Quang is infamous around these parts
I have switched the left wheel to the right. Now I have message that tire pressure has to be adjusted/reset. How to reset? Thanks
Old Aug 7, 2022 | 05:34 PM
clc3251's Avatar
5 Year Member
clc3251 is infamous around these parts
Try driving 20 miles or so.
Old Aug 8, 2022 | 09:16 AM
Quang's Avatar
Thanks. I did but didn’t work.
Old Aug 8, 2022 | 01:54 PM
vkb123's Avatar
5 Year Member
vkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond repute
What year is your car? Also, what tires are you running? Some tires are directional and shouldn’t be moved from one side to the other?
Old Aug 8, 2022 | 02:42 PM
murci930's Avatar
murci930 is infamous around these parts
If you go into the tire settings, and change the charge of the pressure it should make the system relearn.
Old Aug 8, 2022 | 04:24 PM
Quang's Avatar
2010 4S. I use Pilot all season. Thanks
Old Aug 8, 2022 | 04:26 PM
Quang's Avatar
Thanks. I’ll try.
Old Aug 8, 2022 | 07:15 PM
vkb123's Avatar
5 Year Member
Michelin Pilot All Seasons should be fine with side-to-side rotation. I agree with @murci930 that you need to initiate a TPMS relearn through the instrument cluster. Here’s a video showing the procedure. How this works!
https://m.youtube.com/watch?v=fMETwFjQf9I
Old Aug 9, 2022 | 08:57 AM
Quang's Avatar
Do the tire sensor record the pressure or do we enter manually? Thanks
Old Aug 9, 2022 | 08:59 AM
vkb123's Avatar
5 Year Member
Should record automatically but need to drive for a bit for the readings to register.
Old Aug 9, 2022 | 09:01 AM
Quang's Avatar
Thanks all.
cosworth
Aug 31, 2014 10:38 AM
luckyp10
Wheels/Tires
Apr 11, 2011 04:08 PM
damon@tirerack
Wheels/Tires
Jul 4, 2009 01:52 PM
mp57078
Wheels/Tires
Sep 17, 2007 03:40 PM
