Fans blow hard when A/C is on
Old Aug 19, 2022 | 12:50 PM
murci930's Avatar
murci930 is infamous around these parts
I've noticed in the past few weeks (before my shock started leaking ) that my fans blow hard when the AC is on. After some quick googling it seems low refrigerant would cause this. However, after using the A/C recharge cans, the gauge shows that the pressure is right where it should be. A/C blower control unit and relay were replaced 50k miles ago (in 2019). Car is not running hot when the A/C is on either. Are there any other causes (i.e., compressor) or could the refrigerant gauge be wrong?
Old Aug 22, 2022 | 04:27 AM
GemCity970_4S's Avatar
GemCity970_4S is infamous around these parts
What level are the fans set on in the rear / back seat? I notice with my 10' 4S that if the back seat HVAC is turned up it makes the front fans loud
Old Aug 26, 2022 | 11:26 AM
murci930's Avatar
Will definitely try that once the car is back on the road. Thanks!
Old Aug 27, 2022 | 12:54 PM
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
When you hace the desired temperature and fan setting you want you can save it to be recognized by the key by saving your settings on the door buttons. Everytime you enter the car and start it, it will remember your seat, radio, mirrors, and AC temp and fan speed. I think it saves which screen you have displayed on the instrument panel also. Hope that helps!
Old Aug 29, 2022 | 09:55 AM
murci930's Avatar
You were correct, good to know. As soon as i shut off the rear, fans calmed down. Do you have 4 zone or 2 zone?
'02996ttx50
Sep 13, 2018 11:26 PM
slipperyvantage
Jan 28, 2013 08:57 AM
Valley996TT
Dec 19, 2012 10:24 AM
path
Oct 20, 2011 10:37 PM
BLKMGK
Apr 8, 2010 09:51 AM
