Oil temp sensor
Old Apr 23, 2023 | 02:04 AM
melox2's Avatar
melox2 is infamous around these parts
Oil temp sensor
Any one know where the oil temp sensor is on a 971 , not showing a reading on dash
Old Apr 23, 2023 | 04:37 AM
MikeSpillerr's Avatar
MikeSpillerr is infamous around these parts
The oil temp sensor should be located on the oil filter housing. It's a small, cylindrical sensor that screws into the housing. If you're not seeing a reading on your dash, it's possible that the sensor is faulty or the wiring is damaged.
Before you start tearing things apart, though, I'd suggest checking the oil level and making sure that the oil pressure is good. Low oil pressure can also cause issues with the oil temp sensor.
Captain Cove
Aug 21, 2021 07:34 AM
Richard Kellstrom
May 22, 2018 08:45 AM
coolice232
Mar 4, 2012 04:15 PM
Jan 31, 2012 08:25 PM
