Where is the 970 port to connect to iCarsoft V2.0 scanner
I brought an iCarsoft V2.0 scanner for 2016 Panamera. But I can't find any port under the steering wheel to connect the scanner (see attached photo). Where is the port? Is it behind that soft plastic yellow panel?
I removed the panel and found it. It must be push all the way in during the service or emission test.
After payed with iCarsoft, I also found many functions on iCarsoft v2.0 are not supported for Panarema. I am wandering beside services reset and after battery change reset what else does this scanner can do.
