Tech / How To
997 PCM Face removal
Old Mar 19, 2014 | 12:29 AM
TYE's Avatar
TYE
TYE is infamous around these parts
For those that would like to have their PCM and center stack painted, this serves as a DIY for you. You have to get down to the bare faceplate to be able to have it painted, which requires completely disassembling it.
First, to remove the units from the car:
Step 1 - Remove small carpeted trim piece from side of center console by PCM (Beside PCM) Using Torx wrench size T-30
Step 2 - Remove two leather side trim pieces using Torx wrench size T-20, then pull towards rear of car to release the clips
Step 3 - Using 5mm Allen wrench turn four (two each side) black hex locks 1/4 - 1/2 turn to unlatch side locks. Do not force these. They turn very easily in the correct direction. Open glove box on passenger side to access these latches.
Step 4 - Removing retaining screw using 7mm wrench on right hand side of PCM
Step 5 - Carefully slide out PCM
I would recommend you take pics of the faces of the PCM and all units you are disassembling so you can use as a reference for the buttons when re-assembling.
To remove HVAC and trim all the way down, you will see a couple torx bolts, just loosen and slide each unit out.
To remove the faces off the HVAC and panel that holds the sport button, traction control button etc, it is very straight forward. The HVAC has four T6 torx screws on the back of the face. Remove those 4 and separate the face from the unit. This will expose the back of the circuit board and you will see 4 more 6 screws to undo. Once you have removed those, you can take the face off, remove the display, and popping out the buttons is easy.
For the other panel, there are no screws, you just carefully pry the face off. Very straight forward.
Heater Controls
Now to the PCM Nav Unit.
Remove both ***** from front of unit by pulling straight out.
Remove the upper case cover by separating it at the tabs along the center.
Disconnect the CD drive wiring from the circuit board and set the top aside. To remove the faceplate, there is a T8 torx on each side on the circuit board. Once removed pull the face straight out. Carefully do this as there are a few connectors still plugged into the circuit board which you will unplug.
photo 1 (4) by bmwtye1, on Flickr
Now that you have the faceplate off, remove all the T8 torx to separate the back casing.
photo 2 (4) by bmwtye1, on Flickr
One you remove the back you will see this
photo 3 (3) by bmwtye1, on Flickr
Release the tabs for the whole screen unit (white piece in the picuture) and remove the screen assembly.
photo 4 (1) by bmwtye1, on Flickr
Remove the circuit board
photo 1 (5) by bmwtye1, on Flickr
Now you have access to all the buttons that you need to carefully pry out. In this pic im showing you what to push to pop the black plastic cover off the back of the button which will allow the button to fall right out. To remove the Sim card slot, you will need a T6 to remove 4 screws on it.
photo 3 (4) by bmwtye1, on Flickr
All said and done
photo 4 (2) by bmwtye1, on Flickr
Now you have the bare panels ready for paint.
I had mine painted Satin Black. Final pic after re-assembly.
photo 1 (3) by bmwtye1, on Flickr
ID:	348600   Click image for larger version
ID:	348601   Click image for larger version
ID:	348602   Click image for larger version
ID:	348603   Click image for larger version
ID:	348605   Click image for larger version
ID:	348606   Click image for larger version
ID:	348607   Click image for larger version
ID:	348608   Click image for larger version
ID:	348610   Click image for larger version
ID:	348611   Click image for larger version
ID:	348612   Click image for larger version
ID:	348613   Click image for larger version
ID:	348615   Click image for larger version
ID:	348616   Click image for larger version
ID:	348617   Click image for larger version
ID:	348618   Click image for larger version
ID:	348620   Click image for larger version
ID:	348621   Click image for larger version
Old Mar 31, 2014 | 03:39 AM
mkoenigsheim's Avatar
mkoenigsheim is infamous around these parts
Hey TYE - just a very quick thank you - the removal was daunting and your step by step really helped out.
One last point for others who want to do this - learn from my fail. If you have the Porsche fitted telephone module, the cable is identical to the screen socket.....
make sure you reconnect them right - the telephone module goes in horizontal circuit board, the monitor next to the ribbon cable connector!
I plugged my Navi back in, the radio came on and I had no screen - Que. a panic moment.
see photos below of my finished module :-)
I also sprayed the steering wheel Horn surround at the same time. Colour used was a generic satin black.
ID:	353076   Click image for larger version
ID:	353077   Click image for larger version
ID:	353078   Click image for larger version
Old Aug 27, 2016 | 06:18 PM
Zubehor's Avatar
Zubehor is infamous around these parts
sorry to dig up such an old post but what did you guys use to paint the center stack? it does look so much better painted black.
Old Aug 27, 2016 | 09:34 PM
TYE's Avatar
TYE
I brought mine to my bodyshop to have my paint guy paint.
Old Aug 29, 2016 | 09:19 AM
brandonmo's Avatar
brandonmo is infamous around these parts
wow. that does look pretty great. seems like you could also go the route of plastidip if you wanted a reversible change.
Old Oct 5, 2017 | 07:36 PM
LPpfs997's Avatar
LPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to behold
Thanks TYE
Paul
Old Feb 27, 2018 | 05:10 PM
6 Mezger's Avatar
6 Mezger is infamous around these parts
Ok, I'm really going back in time now.
TYE, on your photo with the PCM faceplate completely disassembled you have two clear super small clips sitting right next to the volume button ribbon. Do you remember where they go? I followed your tutorial and now I'm stuck on where those two little guys go.
Thanks for the awesome step by step.
CC
Old Jun 27, 2019 | 06:23 PM
myw's Avatar
myw
myw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to behold
this is awesome (and insane!)
thank you.
Heater Controls
All said and done
Old Apr 1, 2020 | 03:04 PM
GazC2's Avatar
5 Year Member
GazC2 is infamous around these parts
Any tips or pointers on how the small buttons on the AC panel come out don't want to force them and end up breaking something
Old Mar 29, 2023 | 11:45 AM
TYE's Avatar
TYE
Can you be more precise as to your question about where do they go?
plenum
Oct 4, 2015 11:51 PM
Porschedeisgn
Cayenne 958
Mar 19, 2015 11:03 AM
plenum
Feb 2, 2015 09:26 PM
harajuka
Nov 3, 2008 10:29 PM
Periokid
Feb 15, 2008 08:00 PM
