intermittent please check brake lights
Old 10-19-2017, 07:42 AM
BentleyOwnergdc's Avatar
BentleyOwnergdc is an unknown quantity at this point
intermittently the 3rd brake light stops working and I get the message to please check brake lights.... any ideas?
Old 10-19-2017, 08:55 AM
PMS's Avatar
PMS
PMS is offline
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
There is a wealth of information on the HMSL [high mounted stop lamp] / (3rd brake light) here on the forum. Use the search function.
Old 10-19-2017, 09:16 AM
Johnny Hotspur GT's Avatar
Administrator
See this detailed how to by Zaos.
https://www.6speedonline.com/forums/...ent-howto.html
Old 10-19-2017, 09:38 AM
The reason I ask is that I was told it was because I was not using a battery tender. Seemed like an odd answer as I've been driving the car daily
Old 10-19-2017, 09:50 AM
PMS's Avatar
PMS
PMS is offline
It is true that you can get some strange errors if your batteries are low. However, given that you drive the car daily, this seems unlikely (unless your batteries are worn out or your alternator is faulty).
Old 10-19-2017, 12:41 PM
Supposedly batteries replaced before my purchase.... going to have the alternator checked....
Old 10-19-2017, 01:18 PM
sam08861's Avatar
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
Hmmm, I get the same warning once every month or so. Whenever I haven't driven the car for a week or so (which is almost every week), the first start up, I sometimes get the icon/warning on the readout between the gauges. Seems to go away each time after no more than 1-2 minutes of driving. Rear Brake light is working/lights up fine, regardless of the warning.
Will try using the battery tender to see if the low-batt condition might be the culprit. Let me know what you find out and I'll do the same.
Old 10-19-2017, 03:29 PM
will do!
Old 10-27-2017, 10:10 AM
sam08861's Avatar
reporting in... I do think my intermittent case is a battery related item. Observations over the past two weeks are that when driven daily/battery charged, no problems. After sitting for the past 8 days I got the problem again and went away after less than a minute of the car being on. Light itself works no problem, regardless of the dash warning.
Old 10-28-2017, 09:20 AM
PMS's Avatar
PMS
PMS is offline
Thanks for the update. A battery tender (e.g. CTEK) will solve most battery issues. The original advice you were given may be the best solution.
Old 10-28-2017, 10:13 AM
sam08861's Avatar
What original advice was I given? Perhaps you are confusing me with the OP?
Old 10-28-2017, 11:35 AM
PMS's Avatar
PMS
PMS is offline
You are correct. I did make that assumption. At this stage in life, I am easily confused.
Old 11-02-2017, 05:10 AM
daljeetsingh's Avatar
daljeetsingh is an unknown quantity at this point
which car do you have?
Old 11-02-2017, 09:49 AM
PMS's Avatar
PMS
PMS is offline
2005 Bentley Continental GT
Old 01-28-2018, 10:00 AM
pmancari's Avatar
pmancari is an unknown quantity at this point
Question 2007 continental gt - please check brake lights warning
having same issue (SEE PIC)
all 3 lights work and i drive it daily (????)
any help out there?
Quick Reply: intermittent please check brake lights
