Which OBD reader to reset ZF transmission
Old 10-16-2021, 12:41 AM
sirrichi's Avatar
sirrichi is infamous around these parts
Hello
I got a transmission fluid flush incl. transmission oil filter change as maintenance (I do that on all my cars after a few years) and the shifting got even smoother than before. Just on some special occasions I can feel that it is a bit harher than before. I assume the adaption values should be reset as with just driving it takes way loooonger... :-) . On the Bentley it was possible for "my" workshop to reset the values, but on the Aston Martin it is not on a normal workshop software.
Is there a OBD2 reader/scanner that can do that on a 12' Virage with the ZF 6hp26 transmission (like on the DB9 etc with that tranny?)
Merci and have a good weekend
Richard
Old 10-16-2021, 07:51 AM
J doubleU's Avatar
ZF learning process
Vehicle should be at normal operating temperature, transmission shifter in normal mode not sports.
Accelerate from a rest through the gears on a moderate throttleuntil 6thgear is engaged (about 55mph).
Release throttle and allow car to coast down almost to a halt, do not use the brake until the car is at walking pace (if the brake is used at any time whilst the transmission is above 2nd gear the adaption process for this cycle will be aborted).
Note: using a slight uphill gradient will help the car slow much quicker. If traffic conditions necessitate the use of the brakes during theacceleration or coasting process the cycle will have to be repeated.
Hold foot on brake for 15 seconds once car has come to a halt.
Repeat this process a total of 5 times
2-1 Tip in Thump
accelerate gently to 15 MPH
Briskly Decelerate using ample braking power until 1 MPH
"Rapidly" Accelerate using 50%-75% throttle
Repeat the process a total of 6 times
Old 10-16-2021, 08:22 AM
I_gotta_Vantage's Avatar
I_gotta_Vantage is infamous around these parts
Originally Posted by sirrichi
Hello
Richard
A Foxwell will give you all you need for the AM...
Amazon Amazon
Old 10-17-2021, 11:33 PM
sirrichi's Avatar
Thank you for the information but I need someone who already did it with a OBD Scanner. The different manuals from scanners are not clear and I do not want to waste money to buy 2 or 3 scanners ;-).
Old 10-18-2021, 04:28 AM
The Foxwell NT680P covers OBD I, II, III. It can read and clear codes on all AM's... I have a ZF and I can read real time stats on all the modules and clear them if needed...
Check out some Foxwell NT 680 youtube videos... It is the best scanner for all AM's..
Old 09-20-2023, 05:10 AM
Phil57DBS's Avatar
Phil57DBS is infamous around these parts
Could the new Foxwell NT530 do it ?
which menu please ?
which OBD port ?
Old 09-20-2023, 08:38 AM
MRCW's Avatar
which menu please ?
which OBD port ?
I use my Foxwell with the Aston module.
Old 05-24-2024, 02:35 PM
Phil57DBS's Avatar
Sorry i have the NT530 for AM
and I dont find reset adaptions for my Zf 6hp26
Please where in the menu ?
Thank you 😉
Old 05-24-2024, 04:38 PM
Import's Avatar
Import is infamous around these parts
Same here..please..cheers..import
Samhain
Bentley
08-23-2021 08:45 AM
Puddlian
10-24-2020 12:33 AM
Chris P
08-07-2018 10:38 AM
randyb
01-08-2016 08:03 PM
Wildcat1212
06-24-2014 05:25 PM
Quick Reply: Which OBD reader to reset ZF transmission
