Tech / How To
Rollbar Install Instructions
Old Nov 13, 2003 | 06:37 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Lightbulb Rollbar Install Instructions
Instructions are rather simple: Remove the rear view mirror. I did not need too. Of course the seats are already out of the car. Slip the roll bar into the car by rotating it on it's side with legs facing toward the rear of the car. The front legs should be oriented on the bottom when doing this. Carefully get it into the car and slowly rotate the bar up and back towards the final position(If you have a sunroof, be very careful. The mechanics under the roof lining are sharp and the roll bar can cut the liner when it rubs up against it. KPV is aware of this issue) GT2/3 owners will not have this concern). It helps to remove the seat belt height slider units first(Use a flat head screw driver to pry the units off of the bolt the seat belt is attached to. The bolt head has a hole in it where the peg of the adjuster unit sits in, held in by the friction between the peg and the hole. Once it's pried off, the top portion of the unit is held in by two plastic clips that will snap out) you will also need to remove the clothes hook right behind the sliders too. This can be done using a plastic spatula to pry it up and off from the roofline molding. I found it easiest to attach the front legs first that attach to where the front seat belt ring attaches on the door pillar by the rocker panel. Now push the roll bar back into position so that the rear legs line up with the mounting holes on the side of the chassis in the seat well(You will be crushing the plastic rocker panel during this process) I recommend disconnecting the negative on the battery. Another poster indicated that there is some wiring that applies to the airbags running through the rocker panel. You don't want to chance it having the air bags deploy during the positioning process when the rocker panel is crushing. If you have a TT or coupe with rear seats, they will have to be removed. The mounting bolt hole will be visible.***If you have a GT3 or GT2, you are not as fortunate. You will need to cut a hole in the carpet to expose the bolt hole. What’s worse is that the bolt hole is covered by a polypropylene plastic cap. Not just any cap mind you, a screw cap. What makes it difficult to remove is the fact that the cap is flush with the chassis, almost exactly like a bumper plug, so you can get a wrench, pliers or anything on it to get leverage to unscrew it. Use a screwdriver to pry the edges up far enough so that you can use some needle nose pliers to grab a hold of it and unscrew it. Cutting the holes and getting the caps off almost took an hour for me since I did not have the benefit of these instructions.
Position the rear legs so that they line up with the holes. It may be helpful to try screwing in the bolts first to get a feel for the correct angle and orientation of the bolt screwing in. Once the bolts are screwed in, your done...Pretty simple, right???The problem is things just done line up just exactly perfect. I found the rear bolts more difficult to screw in than the fronts. At least with the fronts, the big metal sleeve orients the bolt screw in angle correctly once it's lined up with the hold.
I found no need to use compression straps for this process. Two people are ideal for this job since one can hold the bar into position to line up the holes while the other focuses on screwing in the bolt. If your crazy, like I am, doing it by yourself requires you to hold the bar in position with one hand and screw in the bolts with the other. No easy feat. Best of luck...
PS: You may be asking yourself, once the seats are in, how do I attach the lower seat belt ring to the rocker panel where it was originally attached. It's not a good thought. Basically once the bar is in, you will need to install the seats. Once they are in and you have threaded the belt through the hole on the seat back, you will need to unscrew the roll bar's front mounting leg bolt. Slip the bolt through the seat belt ring then screw it back. I have yet to do this, but am confident that it won't be too difficult. Since the rocker panel is crushed( the roll bar will pretty much stay in position since the other 3 bolts are still attached), you can use some wedges of some sort to keep the front leg into position while the bolt is removed to thread the seat belt ring through it and re-tighten the bolt. Or have some one hold the bar into position for the brief time you have to pull the bolt out.
Follow the link below for photo’s and additional installation tips.
http://gallery.rennlist.com/gallery/albuq52
No warranties whether expressed or implied are offered regarding any of the steps described or required for this modification. Installer assumes all liability.
Old Nov 13, 2003 | 07:33 AM
ColorChange's Avatar
ColorChange is infamous around these parts
Beautiful Rockitman:
Now, I plan on putting in a 6-point harness so I would like to remove the standard belt completely. I would like to remove the sliders and belts, I'm just not clear yet on defeating the seat belt alarm yet.
Old Nov 13, 2003 | 07:34 AM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
Congrats on the install, now lets see some pix!
Old Nov 13, 2003 | 07:41 AM
rockitman's Avatar
Careful Color, you may not be able to pass inspection without the factory belts there too....
Old Nov 13, 2003 | 07:47 AM
rockitman's Avatar
Thanks. I think there may be a performance advantage from a handling standpoint with having the roll bar due to the fact of greatly increased tortional rigidity of the vehical...
I will post photo's in the next day or two....
Old Nov 13, 2003 | 07:53 AM
Sloth's Avatar
You will benefit from increased rigidity and the peace of mind knowing that the roof will not crush you if you forget to keep the shiny side up.
Old Nov 13, 2003 | 07:56 AM
Sloth's Avatar
AFAIK, 6 pt belts are not DOT approved for road use.
Old Nov 13, 2003 | 08:47 AM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Congrats Rockit.
Old Nov 13, 2003 | 09:20 AM
Wow, didn't know that. OK, stock belts stay in and look stupid. I think I will just put in a "fake" buckle in the other end to defeat the sensor.
Old Nov 13, 2003 | 09:37 AM
Chris Y.'s Avatar
Chris Y. is infamous around these parts
Thanks Rockitman!!! Big thanks!!!
Old Nov 13, 2003 | 02:54 PM
toffeGT2's Avatar
toffeGT2 is infamous around these parts
Thumbs up
Awesome Rockitman! Thanks for the instruction, hope it wouldn't take too long for me to install them over the weekend.
Old Nov 13, 2003 | 06:15 PM
rockitman's Avatar
Here are some initial pics of bar in car...
Old Nov 13, 2003 | 06:17 PM
rockitman's Avatar
one more...I will post a link this weekend with more of the process
Old Nov 14, 2003 | 12:09 AM
kparis's Avatar
kparis has a spectacular aura aboutkparis has a spectacular aura about
Rockitman-
can you post a picture of where the front post of the rollbar mount to the floor or rocker panel area?
Old Nov 14, 2003 | 07:12 AM
rockitman's Avatar
kparis,
Here you go. Pick from another install. My pics won't be ready till somethime this weekend...
