Tech / How To
Overhead Console
Old Jul 19, 2007 | 05:22 AM
luvmyC4's Avatar
luvmyC4 is infamous around these parts
Overhead Console
How do I remove the roof panel on my 2001 C4 coupe?
This is the panel were the lights, sunroof switch, etc is located.
Looks like I need to replace my sunroof switch!
Old Nov 3, 2007 | 10:42 PM
Euclid's Avatar
Euclid is infamous around these parts
Pry out the black plastic "dummy" buttons with your fingernail or a credit card or a small screwdriver. This will show 2 Torx screws. Unscrew them and pull down/back on the entire assemble. Should pop right off.
Old Nov 3, 2007 | 10:43 PM
Euclid's Avatar
Once you have it off, you can disconnect all of the wires. Then you can take the entire console out and glue/epoxy the moonroof switch directly to the console. The clips are easy to break and will probably just break again if you replace things.
Glasgo
Nov 30, 2015 02:37 PM
pwdrhound
11
Nov 25, 2015 01:18 AM
miken168
Oct 6, 2015 09:21 AM
rob4wellness
Oct 2, 2015 07:32 AM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
