Boxster S: do i need to drill sensor holes in performance brake pads??
Old Apr 7, 2008 | 04:26 PM
devious986S's Avatar
devious986S is infamous around these parts
hey all,
I figured i'd get the quickest response here, its time for new pads
anyways i was debating between the OEM performance pads or the hawk HPS pads. Also, I and wanted to know if either of these required drilling a hole in order to install the factory sensors??
im ordering:
-ATF blue fluid
-ss lines
-new sensors
-new caliper spring clips
-hps or oem performance pads??
I'd appreciate any help, and any opinions of either of these pads and if there's anything else i should be ordering.
thanks!!
Old Apr 7, 2008 | 05:19 PM
Shawn C's Avatar
Shawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond repute
Sounds like a PITA to me, Ditch the sensors if you plan on doing allot of tracking it will get old fast.
Old Apr 7, 2008 | 05:26 PM
I was thinking about that. But if I don't use them, it won't throw any codes, correct?
Old Apr 8, 2008 | 07:35 AM
Shawn C's Avatar
I would just visually check them once and a while. You should get at least 3-5 track days out of a set of stock pads depending on how hard you drive. I highly recommend Porterfeld R4 though, They are perfect for street and track.
Old Apr 8, 2008 | 03:17 PM
doh! i already ordered the hawk hps pads
so not hooking up the pad sensors wont throw codes right?
Old Apr 8, 2008 | 06:36 PM
Springgeyser's Avatar
Springgeyser is infamous around these parts
No. Just tie off the pad wear sensor off to the side.
Old Apr 8, 2008 | 07:09 PM
alrighty, i appreciate the help!
Old Apr 9, 2008 | 07:15 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Just zip tie the sensors off to the side and use the race pads as they are. If you have any worn out sensors around you can cut the wires and solder them together and make a dummy plug too. Porsche also seels these plugs but I just made my own. BTW, I'd use either Pagid or Performance Friction pads on the Boxster if I was you.
Old Apr 20, 2008 | 01:35 PM
himself's Avatar
himself is a jewel in the roughhimself is a jewel in the roughhimself is a jewel in the rough
The little cap thingy (I think it's the bleeder cap) at the top of the brake caliper is a handy device to hold your wear sensor. No zip tie needed
Also, since you should be checking pressures and torque during a DE, just add looking at brake pads part of your routine. BE VERY CAREFUL when you have almost no visible pad left - since the INSIDE of the pad might be wearing a little faster. You should take your tire off to check, or just change pads a little early.
-td
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
pwdrhound
Aug 23, 2015 07:36 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
