Toyo R888 VS Nitto NT01
Old May 4, 2009 | 04:20 PM
  #31
stuntman's Avatar
stuntman is a name known to allstuntman is a name known to allstuntman is a name known to allstuntman is a name known to allstuntman is a name known to allstuntman is a name known to all
Originally Posted by LarryP
I just ran autocross with the NT01 this Sunday for the first time and they stuck great.As soon as I figured out what pressure to have in them hot (25psi) I could have pushed it even harder. Next time. +1 for NT01 in my book
25psi hot seems a bit low for a relatively heavy car. Was this for autoX or road course? What size F/R?
Originally Posted by porschenaround
the r888's made so much howling noise i couldnt take it, town fair ( i have friends there) took em back and gave me the NT01's but in a 315/235 combo instead of stock sizes, they are not shaved, very grippy on the street (havent hit the track yet) BUT i lost all responsivness and its feeling very disconnected from the road, is that due to tire size being larger ? i have my sways on soft, i will move them to hard tomorrow. . .
How wide were your old tires (R888 I presume?) and how wide are your wheels front and rear?
Old May 4, 2009 | 05:50 PM
  #32
LarryP's Avatar
LarryP is a name known to allLarryP is a name known to allLarryP is a name known to allLarryP is a name known to allLarryP is a name known to allLarryP is a name known to all
autocross track, 25 cold they were 28 when I checked them hot. NT01 didn't even roll over the side that much.I need to push it harder
fronts 235 rears 275
Old May 4, 2009 | 06:46 PM
  #33
stuntman's Avatar
-Makes more sense now. Those pressures would be too low and would roll over on itself in the higher speeds/loads of road courses. Seems like a good F/R split in sizing and that low of pressure would help get the tires up to temp sooner which is important in autoX. How much camber F/R?
Old May 4, 2009 | 09:43 PM
  #34
porschenaround's Avatar
porschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of light
i am running 32 lbs on the street with them, stiffened my sway to full hard in rear, now, the r888's i had in 295 stock size configuration, with the nitto's i went to 315 /235 and its mushyyy !
Old May 4, 2009 | 09:51 PM
  #35
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
When I had the R888s they also howled like crazy. And as the tire wore down the sound got only worse, to the point where I couldnt even hear the exhaust over them.
I just ordered a set of Nitto Invos so Im going to try those out and see how they do. They run $700-800 less per set so even if they arent as good it may be worth it in the long run, but I'll report back after May 18th when I've had a chance to put some track time on them.
Old May 4, 2009 | 09:55 PM
  #36
what made you choose invos ?
Old May 4, 2009 | 09:59 PM
  #37
raiyu's Avatar
Couldnt find any Nitto track tires in the correct OEM fitment and I also decided to run street tires because I like hearing them squeal sooner.
Was running the Michelin PS2s and I love them, didnt have a problem chasing down people on slicks, they only gave out midway through some sessions at the Octopus/carousel (whatever you want to call it) at Thunderbolt, slow constant scrubbing turn, other than that they were great.
Otherwise Im back to the Cups or R888s, one are expensive, the other are noisy, would like to have another option.
Old May 4, 2009 | 10:36 PM
  #38
stuntman's Avatar
Is that 32psi cold for the street? Try bumping them up to 34-36psi to give the sidewall a little more support. That should improve the feeling a bit.
The 'mushy'ness could be explained by increasing the width from 295 to 315 in the rear. If you list your front and rear wheel width, I would have a better idea of the wheel-tire ratio and can better help explain/pinpoint what the issue is.
Old May 4, 2009 | 11:14 PM
  #39
understood, nittos = 315/30/18 235/40/18
Old May 5, 2009 | 07:51 AM
  #40
LarryP's Avatar
I run them at 36psi on the street ,they feel great at that level,I am getting another set of rims with street tires.thats the only way to get rid on the noise
Old May 5, 2009 | 10:35 AM
  #41
stuntman's Avatar
I apologize if I didn't clarify what I was asking for.
Can you list the wheel width front and rear (example: 18x8" front and 18x10" rear)
Old May 5, 2009 | 11:06 AM
  #42
fikse rims = 18x11.5 and 18x8.5
Old May 6, 2009 | 07:15 AM
  #43
turbomx5's Avatar
turbomx5 is a splendid one to beholdturbomx5 is a splendid one to beholdturbomx5 is a splendid one to beholdturbomx5 is a splendid one to beholdturbomx5 is a splendid one to beholdturbomx5 is a splendid one to behold
Like previously stated, both are the same compound but different construction/design.
Billy-
where did you hear this? the engineers at Nitto swear the NT01 has nothing in common with the R888.
-following you from forum to forum.
Old May 6, 2009 | 02:03 PM
  #44
stuntman's Avatar
Originally Posted by turbomx5
Billy-
Suprisingly from people who work at both companies. As a whole, it hard to get reliable information. I havn't spoken directly with the engineers at either since the R888 came out.
Porshenaround - Your tire to wheel sizes look great. Try bumping up the cold pressures a little to improve turn-in.
Old May 6, 2009 | 02:09 PM
  #45
hmm, will do thx !
