queston about spacers and track
Old Feb 10, 2011 | 06:57 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
hey all, just wondering if its considered safe to get on the track (beginner) with spacers?
Old Feb 10, 2011 | 09:27 AM
driver8's Avatar
driver8 is infamous around these parts
It depends on the width of the spacers used. If you are using a wide spacer you may want to use a longer stud bolt. Can you give us more details?
Old Feb 11, 2011 | 01:43 PM
dinorocz's Avatar
mine are 7mm in front and 25mm in rear... the wheels are oem gt3 and also have a stud setup, so the spacer bolts to the cars hub and the wheels bolt to the spacers (actual studs), plus they are hubcentric. Thanks.
Old Feb 11, 2011 | 03:04 PM
2PUTT's Avatar
2PUTT is infamous around these parts
make sure that you use the proper torque specs on everything.
Old Feb 19, 2011 | 06:42 AM
dinorocz's Avatar
yes that is an obvious
Old Feb 24, 2011 | 11:52 PM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
As long as everything is installed correctly and properly torqued you wont have any issues.
Remember not to re-torque your wheels when you just come off the track while they are hot. Always do it when cold.
Other than have fun. =)
Old Feb 28, 2011 | 02:36 PM
dinorocz's Avatar
Thanks, much appreciate the info
Old Mar 2, 2011 | 10:29 AM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
If you are going to use bolt on spacers (most of these are not allowed in race events, though I have asked a couple of PCA scruts, and they can't explain why), then you not only need to check the torque of your wheels, but you need to pull the wheel and check on the torque of the spacers on the hub as well. Check them once each morning and you should be good.
Old Mar 8, 2011 | 07:52 AM
dinorocz's Avatar
appreciate the info IA
Mar48
Aug 24, 2015 01:13 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
