My cheap, fast, and fairly accurate data setup
Old Sep 11, 2012 | 01:57 PM
OneFasTT997's Avatar
OneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud of
I figured I would just post this here since I keep getting asked about it in my youtube videos.
The first video below is actually shot with my iphone and I can upload it to youtube from the track! This requires no PC and the whole process can be managed from your iphone and the editing is done on youtube. If I had a better phone mount and an iPhone 4s the quality would be better but it still is lacking a bit for me as it can't look at the data over multiple laps. It will soon though so it will probably be the easiest way to get the data I want by next year with an iphone 5 doing the video recording.
The other videos are taken on a gopro HD Hero and would look much much better if I stopped being cheap and bought a GoPro Hero 2! I take that video and import it into Dashware. Dashware is very difficult to use until you figure it out. I am only now starting to really get it. The documentation is diabolical and the support has been lackluster at best. There is another program called Trackvision which apparently is better but it costs 3x what Dashware costs and so it went with Dashware.
All of the data you see in my video is captured by my iphone using Harry's laptimer. Here is a video (you need to skip in because the data starts when I cross start finish) that shows what it will look like with Throttle and RPM data:
I didn't add the map or g forces to this one but I could have. Just forgot:
More data displayed here:
In order to do this you need the following.
Harry's Laptimer for the iPhone (if you don't use an iPhone an iPod touch or iPad can be substituted) - http://www.gps-laptimer.de
Emprum UltiMate GPS - http://amzn.com/B005I0JYUY
Satechi CR-3600 Universal Car Holder & Mount for iPhone4S, 4, 3GS, 3G - http://amzn.com/B002K9IPOC
Kiwi PLX OBDII WiFi - http://amzn.com/B002ICSOTC
If you don't plan to record using the iPhone you can buy a GoPro HD Hero II Motorsport edition and Dashware
Two things:
I bought the mount before video was available through the app so I would check Harry's site here (http://www.gps-laptimer.de/Compatibility.html) for better alternatives if you plan to do video that way but the mount I bought seems to be ok.
There is a new option for OBDII data, the GoPoint BT1 (and GL1) which works over Bluetooth which is supposedly better. It doesn't work with Harry's laptimer yet but will soon so it might be worth holding out for.
Let me know if this helps or if you have any questions.
Old Sep 11, 2012 | 05:49 PM
Porsche Pilot's Avatar
Porsche Pilot has a spectacular aura aboutPorsche Pilot has a spectacular aura aboutPorsche Pilot has a spectacular aura about
Can you overlay Harry's telemetry over a GoPro video? Using a third party program of course. I would rather have my GoPro mounted than my iPhone.
Old Sep 11, 2012 | 06:52 PM
Yes. I detail how I do it in the second paragraph and the 2nd and 3rd video are go pro videos.
Old Oct 21, 2012 | 05:09 PM
Slopeslider2's Avatar
Slopeslider2 has a spectacular aura aboutSlopeslider2 has a spectacular aura aboutSlopeslider2 has a spectacular aura about
HLT works awesome, especially with the GoPoint BT1 Bluetooth dongle. I used this set-up this weekend at Roebling Road. Amazing video and telemetry data for around $100 all in. Hard to beat.
Old Nov 12, 2012 | 06:16 AM
monochrom3's Avatar
monochrom3 is infamous around these parts
Nice! I use Harry's also, but it's been glitchy lately for some reason.
Old Dec 6, 2012 | 11:35 AM
BlueJay73's Avatar
BlueJay73 is infamous around these parts
So, you can use Harry's LT with a GoPro camera? You just need to use the Dashware to overlay the data onto the GoPro recording? Will it work with the Bluetooth, or do you need wifi?
Thanks.
Old Dec 6, 2012 | 11:38 AM
BlueJay73's Avatar
Sorry for the redundant questions, its just that this is the first time I've seen information about the ability to use GoPro camera with Harry's LT.
Old Dec 6, 2012 | 01:52 PM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
Subscribed
Old Dec 11, 2012 | 01:22 PM
Thanks.
Yes, you can use GoPro and Harry's with Dashware. Not sure what you mean by Bluetooth or WiFi however.
Old Dec 17, 2012 | 01:00 PM
kaiv's Avatar
kaiv has much to be proud ofkaiv has much to be proud ofkaiv has much to be proud ofkaiv has much to be proud ofkaiv has much to be proud ofkaiv has much to be proud ofkaiv has much to be proud ofkaiv has much to be proud of
Would you mind sharing how exactly you get the data from HLT and embed it in the GoPro video?
Thanks a bunch!
Old Dec 21, 2012 | 09:41 AM
Thanks a bunch!
Sure.
I use dropbox which you can export directly to from HLT. Once the files are there you can import them into Dashware and insert the graphical representations of them. Really the only tricky part is synching them. I have two tricks for this. Usually I set the go pro up where it can see the iphone so I see the time and can synch it that way. If it is too bright out I will look for the first shift point and match it to the data.
Old Dec 28, 2012 | 11:54 AM
BlueJay73's Avatar
Ok, please excuse my ignorance, but…
1--Have GoPro3 camera
2-- Need external GPS (to provide data on where car is), correct? (I have an ITouch, not an IPhone)
3--Need OBD II sensor to provide car data (RPM's, etc.), correct?
What else…?
Harry's Lap Timer OR Dashware OR Trackvision ??? (to sync and overlay video and data) ??
OR, HLT AND Dashware, or Trackvision?
Do I still need to incorporate an ITouch with this if I use Dashware or Trackvision ?
Do I need to incorporate an ITouch if I use HLT ?
Thanks greatly
Old Dec 29, 2012 | 05:49 AM
What else…?
Thanks greatly
The OBD II sensor is really a nice to have but is not necessary to get the laptimes and a lot of other data.
You will need the GPS and Harry's laptimer.
You can overlay the videos in HLT if you want to but it is painful to get the gopro videos onto your IPod touch to do it so I would recommend trackvision OR dashware (I chose dashware due to cost).
Hope this clears it up.
Old Dec 31, 2012 | 10:25 AM
dasams's Avatar
dasams is infamous around these parts
For those just getting started, all you need is an iPhone, HLT ($20 in iTunes) and the GoPoint BT1 for the throttle, rpm and gear info ($99). dave
Old Dec 31, 2012 | 01:58 PM
dam2's Avatar
dam2 is infamous around these parts
Nice! I just bought a telemetric system for next season, cannot wait!
PV=nRT.
Sep 9, 2022 06:06 PM
danyoP4S
Sep 30, 2021 05:06 AM
Texas1
Sep 20, 2015 09:12 AM
HotRod
Sep 10, 2015 07:17 PM
