Auto-X car recommendations?
I'm thinking about picking up a dedicated car for auto-x-ing next summer. Anyone have any recommendations? I'm looking for something moddable, under $50k (including mods), and street-drivable (don't want to have to trailer). I was thinking maybe an Elise? Anyone have any good first-hand recommendations? What works particular well on the auto-x circuit?
Thanks in advance - Josh
Well if you want something relatively new and streetable i would recommend a cayman S or elise/exige
If you want something more aggressive and still streetable, an evo or my personal favorite a b5 s4 with stasis ohlins and alcon brakes.
With the porsche or the lotus, you will be pretty close to your limit right out of the box, just keep in mind you could build a pretty fast/track oriented car for 50k...
Kind of depends what class you want to run in, assuming SCCA Solo. For the money, I'd go with an Evo 9 in street prep'd. Gut the interior, intake/exhaust/flash/moreboost, and few things will touch it on slicks.
Originally Posted by Chris from Cali
If you want to spend half that and have a great time, get an S2000... Super reliable, drive to and from the event, etc. etc.
Boxster will make you look at lot better than your experience. I finished 2nd at a PCA event (to an X50 996 TT) in my 1st event. The cars are awesome autocrosser and you can buy a 2.5 for $13-16k or a 2.7 in the upper teens. An S2000 is a great option as well.
EVO for sure, or a Miata if you don't mind driving a chick car. I had a Mk. I Elise, and it had no bottom end, which isn't good coming out of the tight corners of a typical Auto-X track. Elises are much better at carrying speed through corners, IMO, which is not what you find at many converted parking lot / Auto-X courses. EVOs, on the other hand, simply rule.
May be out of the budget but would be a mighty fun car at auto x:
http://www.arielmotor.co.uk/04/frames.htm
If your within an hour or two of the Maryland/Delaware line you should check out our April event. www.pcachs.org
