Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
Old Sep 26, 2009 | 08:18 PM
  #3136
cjv's Avatar
cjv
Moderator
Mike,
Right now I'd be happy to get the motor assembled, installed and tuned.
We know what we are going to do with the front end and the lifts. We are starting to look at what other manufacturer's have done. An example is BMW with the BMW RSR ABS system. It can be installed and integrated on the 996tt for about 12K and it beats anything Porsche currently has hands down.
Audi has a superb awd system ...... we are looking at that along with some other things that are out there.
After analyzing the center locks, we decided to pass. The big advantage of the center locks and BBS wheels was weight. The wheels weighed about 16 pounds. However, I have found magnesium/cf wheels that weigh 14 lbs. It appears the only thing the center locks now have going for them is they look cool. However at the cost for being cool ..... I'll pass.
That brings us back to the wide body. I like it, the wider stance will slow top end down, however handling should be better. We are looking at it right now. The cost for the wide body through prime paint is about 26K. It allows for a lot of tire choices, but nothing over 335's. The main benefit seems to come down to the improved handling offered by the wider stance but at the cost of wind resistance at higher speeds.
Old Sep 28, 2009 | 07:54 PM
  #3137
cjv's Avatar
cjv
Moderator
Things are moving better than I anticipated.
The motor assembly has started.
I also have some very exciting news. Anyone setup their motor without any MAF? I have a brand new MAF which I purchased from Protomotive (never installed) and I am now considering not using it. I have run across some F1 technology in the forum of an ECU that will take over all motor functions from the 996tt ECU. I can run a MAF or utilize speed density. I can also take over such functions as ABS or PMS. You heard that right ....... PMS.
We will require some harness made and the motor will be tuned on an engine dyno.
I'm so excited!
Old Sep 28, 2009 | 08:03 PM
  #3138
cjv's Avatar
cjv
Moderator
996tt motor without using a MAF
Has anyone heard of our motors operating without a MAF.
I believe the world is changing again ........ big time.
Old Sep 28, 2009 | 08:09 PM
  #3139
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
On factory ECU? We ditched our MAF a few months back with a little help from a M800.
Old Sep 28, 2009 | 08:13 PM
  #3140
cjv's Avatar
cjv
Moderator
Does the M800 use speed density? Can your M800 also take over control of ABS and PSM. I don't believe any Motec has the capabilities of this system.
Old Sep 28, 2009 | 08:14 PM
  #3141
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Justin N from Tuning Concept/Boost Logic has been running his home built standalone for 6+ months now running in Speed Density. I think he is one of the first few setups to not have a million lights on the dash going and he's done it all by himself. I'll let him explain more about the setup.
As far as stock DME, I did not know either! I always look towards you when new innovations come about so if you didn't know I def. didn't know it was possible.
Old Sep 28, 2009 | 08:20 PM
  #3142
cjv's Avatar
cjv
Moderator
Powell.
I was introduced to it today while trying to install a BMW RSR ABS system on the 996tt. This is F1 technology. It runs with the 996tt ECU. It can take over any 996tt ECU function desired or incorporate a totally new function.
Old Sep 28, 2009 | 08:22 PM
  #3143
onelove's Avatar
Factory ECU is still in the car handling these duties, M800 handles all the good stuff. The possibilities with integration are endless, datalogging, multiple maps on the fly, antilag, the works. Still have a few bugs to work out but it's been quite a bit easier than most in this market make it out to be.
Old Sep 28, 2009 | 08:24 PM
  #3144
Powell's Avatar
That sounds pretty trick right there! I am not sure on the limits of what Justin is using, only parts I know that it controls is spark, fuel, etc. I am going to be using his setup possibly when I do my motor build. Nothing beats live tuning!
Any idea of the cost of the system you found? I'm guessing pretty pricey, but it maybe worth it for someone like you who has got the baddest 996TT motor around!
Old Sep 28, 2009 | 08:28 PM
  #3145
cjv's Avatar
cjv
Moderator
Hold on to your seat. The system with harness is less than $3,500.00. This does not include tuning.
Old Sep 28, 2009 | 08:34 PM
  #3146
Powell's Avatar
Really!? Wow!!! Send me a link in a PM (since I'm guessing they aren't a sponsor). I'd really like to check this system out!
Old Sep 28, 2009 | 08:35 PM
  #3147
onelove's Avatar
Oh ours also uses a jumper harness, aside from putting a MAF back into the car, we simply unplug the jumperharness, plug the factory ECU back into the factory harness, and it runs just like stock once reflashed.
Old Sep 28, 2009 | 08:38 PM
  #3148
onelove's Avatar
Killer price. I think competitive products will be making their rounds after PRI. Motec is releasing their new line of ECU's more focused towards street cars and priced effectively as well. Haltecs latest line of platinum ECU's are also quality pieces competitively priced
Ultimately once you remove the MAF you free up the future towards huge HP without limitation, as well as the many different features offered in standalones (custom boost / speed or gear, antilag, launch control, traction control, data logging all the time without having a laptop in the car, etc).
Old Sep 28, 2009 | 08:40 PM
  #3149
teflon's Avatar
teflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant futureteflon has a brilliant future
...I can also take over such functions as ABS or PMS. You heard that right ....... PMS...
Chad,
That's great news! I know I'm not alone when I say that I can't wait to hear that your car is running and back on the road.
However, despite what you may have been told, PMS is totally uncontrollable. I'm sure you meant "PSM".
Greg A
Old Sep 28, 2009 | 09:06 PM
  #3150
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
Yes. we have tuned several cars this way while retaining the ABS / PSM. Car runs perfect without the MAF
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
