Wheels/Tires
Will a 235 fit on a 7" Wheel?
Old Dec 24, 2007 | 08:02 AM
NYSpeedRacer84's Avatar
NYSpeedRacer84 is infamous around these parts
Will a 235 size tire fit on a 7" wheel? if you not what is the min that a 235 tire need?
Old Dec 24, 2007 | 01:32 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
If you are speaking of an 18" or 19"wheel, will it fit? Probably yes. Is the the recommended rim width? No. Most tire manufacturers recommend 8" minimum for 235/18.
Old Dec 24, 2007 | 01:52 PM
NO, it's the stock 17" Wheel
Old Dec 28, 2007 | 06:32 AM
damon@tirerack's Avatar
Moderator
No. Most 235's have an 8" minimum rim width requirement.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Dec 29, 2007 | 04:32 PM
Damon,
How about a 225 on a 6.5" Wheel?
Old Dec 30, 2007 | 12:34 AM
r34dy2walk's Avatar
r34dy2walk is infamous around these parts
what car are you putting these tires on?
Old Jan 7, 2008 | 01:55 PM
CosmosMpower's Avatar
CosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud of
235 is a bit wide for a 7" wheel. The min width I'd use is 7.5" But you can probably make it work depending on the wheel and tire brand/model.
Old Jan 8, 2008 | 01:21 PM
sandvik996tt's Avatar
sandvik996tt is infamous around these parts
It will look weird !
Aug 21, 2015 09:56 AM
pwdrhound
Aug 20, 2015 05:54 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
