Wheels/Tires
Tire bulge - what happened?
Old Aug 21, 2008 | 07:13 AM
waymegelli's Avatar
waymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the rough
I'm getting ready for a track event and was changing out my normal Kumho street tires for my track tires. When I removed the right rear Kumho, this is what I found. See attached pictures. These tires are 12 months old and have only 5000 miles on them, although that includes 3 DE events. In 2 of those DE, I shared the car with my son so it got double abuse those times. Is this a tire defect? A mounting defect? Using them too hard?
Clarify tire use - It was just recently that I bought track tires. These Kumhos have been on the car for 12 months and were used for the DE events.
Old Aug 21, 2008 | 11:57 AM
surfingbuddhist's Avatar
surfingbuddhist has a spectacular aura aboutsurfingbuddhist has a spectacular aura about
Looks like a tumor
Seriously, I've seen that before from curbing a tire. Can't really tell from the pics if there are any marks on the tire.
In any case, looks like it should be replaced asap.
Old Aug 21, 2008 | 12:12 PM
speedoflight's Avatar
speedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud of
holy crap that looks bizarre. i had at one point spun at the track and ended up on gravel. some gravel stuck in between the tire sidewall and the rim which caused it to deform a bit but nothing as exaggerated as that. deflated the tire, removed gravel, reinflate, and tire came back all normal. yours look more like tire defect?
Old Aug 21, 2008 | 01:41 PM
Tech1_Mike's Avatar
Tech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond repute
The tire radial belt is damaged and near total failure. It must be replaced.
Probably due to pothole, or some stationary object impact, IMO.
Old Aug 21, 2008 | 04:29 PM
HREMarc's Avatar
HREMarc is infamous around these parts
I agree with Mike^^. When you dismount the tire you will see a "pinch" mark on the inside of the tire.
Old Aug 22, 2008 | 12:40 PM
damon@tirerack's Avatar
Moderator
Yep, most likely hit something that de-laminated the interior plies of the tire. Air getting into the tire is making the bulge grow. We see it all the time on the inside. It may have happened weeks or even months ago.
Replace it.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Aug 22, 2008 | 07:03 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
Your life is valuable.
Recycle the tire!
Old Aug 23, 2008 | 07:11 AM
waymegelli's Avatar
Got it - replace tire. So I guess I'll replace both rears - there wasn't a lot of life left in them anyway. Kind of surprising for Kumhos with only 5000 miles, even though some of them were pretty hard.
Old Aug 23, 2008 | 10:00 AM
Steve Germany's Avatar
Steve Germany is infamous around these parts
I see two areas of delamination. I may be possable that there was some tire mounting damage that finally gave away. When you have the tires unmounted I'd talke a look inside.
One other possability is that the tires were run in two different directions (not always on the same side of the car) which can cause ply seperation as well.
Old Aug 25, 2008 | 01:48 PM
RaminGTI20's Avatar
RaminGTI20 is a jewel in the roughRaminGTI20 is a jewel in the roughRaminGTI20 is a jewel in the roughRaminGTI20 is a jewel in the rough
i have those tires on my VW....they cant even get my car traction so i have no idea how your 911 is holding up with them . anyway i have a small bubble in my rear tire too....stupid backroads leading to my house have some rough bumpy pavement are to blame. get some pilot sports or pirellis
Old Aug 25, 2008 | 06:04 PM
turbo turbo's Avatar
turbo turbo is infamous around these parts
i have same problem, i just noticed it today.
Old Aug 25, 2008 | 07:09 PM
Leviathan's Avatar
Leviathan has a reputation beyond reputeLeviathan has a reputation beyond reputeLeviathan has a reputation beyond reputeLeviathan has a reputation beyond reputeLeviathan has a reputation beyond reputeLeviathan has a reputation beyond reputeLeviathan has a reputation beyond reputeLeviathan has a reputation beyond reputeLeviathan has a reputation beyond reputeLeviathan has a reputation beyond reputeLeviathan has a reputation beyond repute
your tire is pregnant. put it in a warm garage and after 9mos you'll have 4-8 powerwheels tires
Old Sep 1, 2008 | 09:04 PM
Steve's 996's Avatar
Steve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud of
Looks like a pothole was the culpret. I live in an area where pot holes grow pretty large. I've had this happen with different brands of tires with varying degrees of damage. Time for a new tire.
Old Sep 2, 2008 | 04:56 PM
Springgeyser's Avatar
Springgeyser is infamous around these parts
Time for 2 new rear tires.
drapersa70
Jan 19, 2016 10:01 PM
L.A.P.
Oct 19, 2015 10:01 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
Zero911
Aug 24, 2015 06:51 PM
L.A.P.
Aug 23, 2015 11:48 PM
