Wheels/Tires
New Wheel Sizing Help Please
Old Jan 18, 2016 | 08:45 PM
MotoJB's Avatar
MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !
New to P Cars...and doing custom wheels in general...I just bought Zulu's/John's '01 996 Turbo.
I am going to a set of 18" wheels - 18x8.5 front and 18x11 rear - and need help with recommended offsets please!
The car is currently slammed on coil overs and is currently running some 19" BBS F1 wheels, that came off a 997. They have 245/35/19 fronts and 315/25/19 rear tires and are both pushed out with what look to be 1/2" spacers and longer lug bolts. No rubbing what-so-ever.
My wheel/tire considerations are:
  • 18 x 8.5 w/ 225 or 235-245/40/18
  • 18 x 11 w/ 295 or 315/30/18
(I'd prefer to run the wider tire configuration if possible but am concerned about clearance/rubbing)
As I understand, stock rim sizes and offsets are:
  • 18 x 8 50mm
  • 18 x 11 45mm
I have a 996TT buddy with factory suspension that suggested I go to the same offsets he is running (to push them out a bit):
  • 18 x 8.5 et45
  • 18 x 11 et38
My wheel mfg however just came back today with these recommendations:
  • 18 x 8.5 et47
  • 18 x 11 et42
"This will be 3mm more aggressive than the oem fitment based on the information we have. Now keep in mind that's on OEM ride height. You're lowered on coil overs and we can't estimate the amount of camber you may have. If you want we can make them right in the middle of the offsets your friend is running and with what we know, should work without any issues."
I would prefer to run:
  • 18 x 8.5 w/235 or 245/40/18
  • 18 x 11 w/315/30/18
Can anyone please help a newbie understand what rim offsets and tire sizes I should consider going with?
Other questions please:
I'll be changing my lug bolts - OEM lugs are ball seat but the rim maker normally makes the wheels conical seat. They can make ball seat if I want. What do you suggest I go with?
Thank you for any help you can provide. Much appreciated.
Old Apr 3, 2016 | 12:19 PM
jason952's Avatar
jason952 is infamous around these parts
What did you end up with on sizing and lug seat? They look great btw
Old Apr 3, 2016 | 12:38 PM
MotoJB's Avatar
Thanks!
18 x 8.5 et45
18 x 11 et38
Stock tire sizes (for now). Pushed out an additional 7mm front/rear.
Ball seat.
Raider89
Nov 8, 2017 06:51 PM
SethW
Wheels/Tires
Jan 29, 2016 02:12 PM
Cuda911
Dec 21, 2015 06:51 PM
Red911TT
Dec 10, 2015 10:54 PM
Dpm7471
Dec 6, 2015 10:39 AM
