Wheels/Tires
Max wheel width and offset for narrow body?
Old May 23, 2006 | 01:44 AM
calicolin's Avatar
calicolin is a jewel in the roughcalicolin is a jewel in the roughcalicolin is a jewel in the roughcalicolin is a jewel in the rough
What's the most aggressive (i.e. widest) width and maximum offset you guys have done to a narrow body 996 without rubbing? I'd like to hear some of your experiences, and pictures would be nice too. I've seen some pretty wide lips on narrow bodies. Who's got the most aggressive setup?
Old Dec 16, 2006 | 11:01 PM
82targa's Avatar
82targa is infamous around these parts
i would also like this information
Old Dec 21, 2006 | 07:12 PM
PTarga's Avatar
PTarga is infamous around these parts
According to Lucent, max rear width is 11". Most people go with 8.5" in front. I prefer to stick with 8" in order to avoid spacers.
Old Dec 23, 2006 | 07:02 PM
20C4S's Avatar
for the street i will not run anything more aggressive than ET52 on a 11''. that's for the rear of course. a ET56 or anything around there would be ideal.
Old Dec 23, 2006 | 10:59 PM
damon@tirerack's Avatar
Moderator
Agree. Have had my fair share of headaches from people who insist on using widebody fitments and thinking a fender roll job is all they need to make it fit.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Dec 24, 2006 | 12:01 PM
MarkT.Bevans+'s Avatar
MarkT.Bevans+ is infamous around these parts
Damon
Are you saying that we (996 narrow body owners) can fit a 11" wide riim on the rear? As for myself I have been wanting to put a set of wide 18"s As long as I need not roll my fenders. But with many of us, we do not want to buy a expensive set and not be able to fit them in place.
But 20C4S statedthat anything between a 11" ET52-56 will fit on the rear of a narrow body. Is this correct?
Thanks much
Mark
Old Dec 24, 2006 | 12:22 PM
20C4S's Avatar
Originally Posted by MarkT.Bevans+
Damon
Thanks much
Mark
mark,
to answer ur first question, the 996 GT3 has 18x11 wheel in the rear with ET63 offset. so the 11'' will fit but u'll need to roll the fender. rolling the fender is not a big deal as long as u find the right place that has the right tool.
i'm always careful on my replies because i don't want to give people wrong infomation. on ur second question, yes anything between ET52 - 56 will fit but it's not a bolt-on fit. couple factors that will change the result such as ur current ride height, camber, fender. the car needs to be dialed right to look right & drive right. for example, if u just slap on a 11'' wide wheel with 305/25-19 tire without changing the alignment set up the wheel/tire will stick out of the fender about 1/4'' to 1/2''.
Old Jan 6, 2007 | 02:58 PM
Thank you 20C4S
Then I should be able to run a 10x18 et65 in there rear?
Old Feb 7, 2007 | 10:27 PM
DeAd-EyE's Avatar
DeAd-EyE is infamous around these parts
the wheels i have now fit perfect
they are 9inch front ET35 and 11inch rear ET55
no rubbing
Old Feb 27, 2007 | 10:40 PM
sms's Avatar
sms
sms is infamous around these parts
dead-eye - that is the widest I have seen on the front of a NB car.
Do you track you car and still have no rubbing?
Old Feb 27, 2007 | 11:22 PM
DeAd-EyE's Avatar
SMS, i have ZERO rubbing and the fitment is absolutly perfect and my car has been tracked with the setup. i could probably go 235 at most at the front with no rub. they're also for sale..let me know if you want em
Old Feb 27, 2007 | 11:50 PM
sms's Avatar
sms
I was eyeing them before, but I really do not want to do the centerlock conversion.
Good luck and someone is going to get a great deal!
Old Feb 28, 2007 | 10:26 AM
Wheel Experts's Avatar
For most narrowbody 996 cars, you can typically run a 11" with et 58-65 and the 305/25/19 with no issues. If the ET between is 52-58 some minor adjustments may be needed like Arling said, camber/alignment and/or fender rolling, if the car is lowered. With factory height it is usually not an issue.
I am also in agreement that the et52 would be as aggressive as I would go on a 11" wheel - this is the TechArt Formula fitment.
Old Mar 11, 2007 | 06:55 PM
wittenbergj's Avatar
wittenbergj is infamous around these parts
Would these fit:
Front: 8.5J x 19 with 235/35 ZR 19 tires, wheel offset: 55 mm. Rear: 11.5J x 19 with 305/30 ZR 19 tires, wheel offset 67 mm.
Note the 11.5 rears ?
Old Mar 11, 2007 | 07:19 PM
tires are too tall in the rear for a 996 narrow
