ignition switch failures
Old Sep 10, 2009 | 07:29 AM
YoopsRacing's Avatar
YoopsRacing is infamous around these parts
Are 996s notorious for the ignition switch to lock up causing the key to stick or impossible to re insert over time?
Need some facts plz.
Old Sep 10, 2009 | 08:59 AM
deckman's Avatar
Yes they are. There are two options, one is a simpler cheaper DIY job with an inexpensive part from the dealer and the other is a long term expensive fix. Do a search on RennTech for the DIY article and discussion.
Old Sep 10, 2009 | 11:11 AM
John L's Avatar
John L is infamous around these parts
I'm personally on my third ignition switch in just a total of 66k miles on my car. It'll first feel mushy when yoiu turn the key, you may have a electrical gremlin like headlights won't turn on etc, and then the key will be next to impossible to remove or if you do get it out, re-insertion is impossible. I'm told the latest fix is an Audi switch which is supposed to fix the problem.
Old Sep 10, 2009 | 11:33 AM
uberpoop's Avatar
uberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond repute
Like Deckman said there is stuff on renntech about this.
I did opt to change out the entire switch assembly with the upgraded one, as opposed to just the cheaper swap of just the smaller piece.
Not too hard at all, only one 10mm bolt is a bit hard to get to.
Overall it is a 2-3 beer job. not too bad.
Old Sep 10, 2009 | 11:45 AM
Dealer wants $177 for the part and around $425 to install
is this the upgraded part #
9963470170717643
Old Sep 10, 2009 | 01:37 PM
deckman's Avatar
The part # looks right except the last five digits. I don't know what they are for.
Old Sep 10, 2009 | 01:52 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
The dealer no longer sells the ignition switch separate from the lock assembly. It is still available at online vendors for around 30 bucks. Takes maybe a half hour first time you install one, quicker after that.
4A0 905 849B is the part number for just the switch portion. This is also the switch used on the audis.
Old Sep 17, 2009 | 08:24 PM
01vdpsc's Avatar
01vdpsc has a spectacular aura about01vdpsc has a spectacular aura about01vdpsc has a spectacular aura about
This guy has step by step instructions including pictures of how to do the job,
http://www.gagme.com/greg/996/ignition.php Hope this helps.
Old Sep 18, 2009 | 08:31 AM
Thanks a ton for the link -
Old Sep 18, 2009 | 12:51 PM
01vdpsc's Avatar
FYI: I did get permission from the guy to link his page here.
Old Sep 18, 2009 | 01:18 PM
And please let him know that I appreciate it !
Old Sep 26, 2009 | 01:40 AM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Just picked up an ignition switch for $8.65! Thanks for the DIY link!
Old Nov 2, 2009 | 01:27 PM
nijoma's Avatar
nijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud of
I am having this same problem
All I need is the switch for 10.00's? The dealer is telling me I need a lock out switch housing the part I was quotes was 119.00 at suncoast. I do trust them, is it that the dealer no longer sells the parts seperately? I am going to install myself looks pretty easy.
Old Nov 2, 2009 | 06:59 PM
Mother's Avatar
Mother is infamous around these parts
Tip: Since these switches go bad so often on my last change... one of many last weekend I removed also those stupid plain screw driver type set screws in the housing that hold the switch with allen head type set screws that are about 3/4" long from Ace hardware sorry but forgot the pitch but they are size 4.
Old Nov 3, 2009 | 03:08 PM
JJShaffer's Avatar
JJShaffer is infamous around these parts
No sooner have I read this post that I am probably going to be performing this in the not so distant future. Many thanks to those who have made the pictorial to assist.
Shaf
