Lord help me... I have Gremlins!
Its not the classic car that we all desire that I am referring too, but my 2003 Cayenne is doing or not doing a bunch of odd stuff and I could use some advice.
1. No air blowing out of the center dash vent. The other fronts work great.
2. No air out of the rear vents.
3. Neither of the heated front seats heat. All other controls work on them. I checked every fuse on both fuse boxes on each side of the dash. They were all fine.
4. My bose, cd, stereo, poweramp gave me an error message and didnt work this morn.. Screen came and showed a radio station but no sound. Let it sit all day, works now but the song that it says it is playing on the radio is stuck on "slash". I did a #1,4,8 reset and no change.
5. Batt was dead were it would not start one day but has been fine since.
Everyday it is something new. Will keep the post updated as more happens.
Well I could be wrong because mine only has one but isn't the second one in back and easier to get to? If so I'd start there. But...the main battery is probably a more likely suspect. It's a pain to get to under the driver's seat though.
Easy.. check the codes with either a Durametric or PIWIS and troubleshoot from there. If you are not good with diagnostics, then take it to a indy mechanic or dealer.
I didn't know how in depth the Durametric would get. From some reading it didn't seem like it would tell me much. If it could help me with stuff like the vent problem I will order one tomorrow!
battery
You guys are correct! My under-the-seat battery is bad. 10 volts when not running and obviously will not pass a load test. It will start and run just fine though so rear batt is hanging in there. Does anyone know of the part # for the front batt on the 2003? The auto parts store just lists one batt and I don't want to get it home and apart to find that it is wrong. I have googled like crazy and have had no luck. Thanks!
When mine went dead I didn't have much of a chance. It was Sunday and the only place open just happened to have one in stock so I bought what they had. Personally I prefer Interstate batteries if I have a choice but I just took the battery in to the parts place and they gave me the replacement one. $150 or so. It's a big honkin battery.
Sorry I know that doesn't help much but if they say it will fit it should work.
Sams club shows the same batt for 03 to 08 for 120 bux. they don't say anything about 2 Batts for the 03. They had no clue if the aux batt was the same or not and no one seems to.
Update. The sams club batt will fit under the seat. It is quite a bit larger than the interstate batt recommended. Batt replacement fixed my radio and no start issue. Problems 1,2,3 are still there. Will a durametric diagnose vent and seat issues?
kahala997s
09-15-2015 05:15 PM
