6speed Technical Information forum This area is intended for members to post their technical questions that will be answered by anonymous experts posting as 411. Members may provide knowledge but sponsors are asked to not post in this forum.
Abs psm failure
Old Nov 4, 2018 | 01:46 PM
kkw1027's Avatar
kkw1027 is infamous around these parts
Abs psm failure
2009 Boxster 2.9l, 17,000 miles,
came home last evening, parked in the garage, no issues.
Started car car this noon, ABS.PSM failure warning is lit up, drove about 10 miles, operation is normal, brakes, etc
any ideas?
Old Nov 6, 2018 | 06:28 PM
Macster's Avatar
any ideas?
A tech can probably query the ABS/PSM system for any errors and make an informed diagnosis. Absent a professional tech's diagnosis my WAG is a wheel speed sensor is bad. By "bad" I mean the sensor could really be bad, have failed, or the wiring harness may have experienced a broken wire, or just a speed sensor connector could be "loose"
If you had any work done on the car recently and in the area of the wheels/tires I'd probably suspect a loose connector..
Wealth Manager
May 12, 2015 11:15 AM
Wealth Manager
Mar 28, 2015 08:40 AM
M3CAB
Sep 2, 2004 05:53 AM
jro
Apr 30, 2004 08:08 AM
MarkL
Jan 31, 2004 03:53 AM
