Air bag warning error light
Old May 7, 2017 | 06:18 PM
1992964cab's Avatar
1992964cab is infamous around these parts
1992 964 Cab. I recently replaced my battery and now the air bag error light is on. I'm thinking if I unblug the airbag control module and reconnect that may solve this. Any one share where the control module is?
Old May 30, 2017 | 09:38 PM
Ebola's Avatar
Ebola has much to be proud ofEbola has much to be proud ofEbola has much to be proud ofEbola has much to be proud ofEbola has much to be proud ofEbola has much to be proud ofEbola has much to be proud ofEbola has much to be proud of
Have you checked the clock? If memory serves me correctly, sometimes the airbag light is caused by the connection going bad in the clock. You would need to test and re-solder the bad connections.
Old Apr 2, 2020 | 05:56 PM
Carheli's Avatar
Carheli is infamous around these parts
Have you tried to reset with a piwis
911Spdstr
Apr 26, 2010 12:22 AM
OhioC5
Oct 30, 2009 01:39 PM
onebadna1nsx
Cayenne 955/957
Feb 15, 2009 11:13 AM
bchow83
Apr 18, 2008 09:38 AM
maxjamie
Mar 4, 2005 06:05 AM
