Pirelli trofeo R
Old Jun 7, 2014 | 08:28 AM
yeguy's Avatar
yeguy is infamous around these parts
Pirelli trofeo R
I tried the Pirelli trofeo R with the Turbo S and they didnt last long. 2 track days, about 8 twenty min session equivalent to 200 miles.
I were surprised at the low durability of there tires. Tracks were homestead and west palm (1 day in each).
Old Jun 8, 2014 | 06:14 PM
TFSweet's Avatar
TFSweet is infamous around these partsTFSweet is infamous around these parts
Wowwww. I guess thats what happens with such a super sticky tire?? It looks like you had tons of fun out there on the track!
Old Jun 10, 2014 | 10:34 PM
BOXER12's Avatar
BOXER12 is infamous around these parts
Looks like someone was a bit hard on the gas coming out of slow corners???
Old Jun 21, 2014 | 02:21 PM
superman32's Avatar
superman32 is a jewel in the roughsuperman32 is a jewel in the roughsuperman32 is a jewel in the roughsuperman32 is a jewel in the rough
what presure were you running? Looks like pressure too high.
These tires need run 2bar hot
Old Jun 22, 2014 | 08:41 PM
yeguy's Avatar
Hi,
I put pressures recommended by Porsche for track 31 psi cold front and 36 back
Old Jun 23, 2014 | 12:49 AM
superman32's Avatar
Originally Posted by yeguy
Hi, I put pressures recommended by Porsche for track 31 psi cold front and 36 back
that is for oem tires.
Trefeo r recommended hot pressure is 30psi hot.
If you put 31 cold and 36 cold hot pressure will be like 43-48 way too high.
That is why only the center parts of your tires are worn. That means pressure you set is too high. Your tires side parts do look ok.
Old Jun 27, 2014 | 11:58 AM
TAGMotorsports's Avatar
TAGMotorsports is infamous around these parts
I was going to second that.
How did the fronts wear compared to the back?
Old Jul 8, 2014 | 05:27 PM
camisade's Avatar
camisade is infamous around these parts
Beginning to wonder if this car is simply hell on tires using the stock alignment settings? I completely toasted a set of Pirelli PZero's in two track days at Putnam (which, admittedly is a road course known to be hell on tires). New Michelin Pilot Sport Cup 2's are a little more durable, but are still getting eaten a lot faster than the same type tires on my 997-2 GT3...
Old Jul 13, 2014 | 02:49 PM
allans's Avatar
allans is infamous around these parts
May I ask where you are buying PSC2's ? I can,t find them. Thanks, Allan
Old Jul 13, 2014 | 04:03 PM
WearyMicrobe's Avatar
WearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond repute
Your not the only one with wear issues with improper PSI.
http://rennlist.com/forums/997-gt2-g...-r-report.html
couple guys in this thread showing good wear resistance on the newer model. The old ones wore out instantly IMO and the new version was supposed to last a bit longer then normal.
But 500+hp and all wheel drive on a track that eats tires, your going to have increased wear.
Old Jul 13, 2014 | 04:04 PM
camisade's Avatar
I get them at TireRack (tirerack.com), and have them heat cycled before shipment for optimum track durability. Then I have them mounted at my Porsche dealer, often in conjunction with a pre-track, in-depth tech inspection, just to keep an eye on things.
randalldahme
Feb 19, 2016 03:56 PM
johnspeed
Oct 1, 2015 09:17 AM
WheelB
Sep 30, 2015 10:19 AM
Sep 25, 2015 10:10 AM
