Spoiler failure
Old Mar 16, 2018 | 01:38 PM
Anthony997.2's Avatar
Anthony997.2 is infamous around these partsAnthony997.2 is infamous around these parts
Spoiler failure
Hi guys,
Recently on the freeway had the spoiler failure message in red pop up. The front and rear spoiler do work perfectly manually at lower speeds though but it is only once I reach the deployment speed that the message pops up and that the system is deactivated.
I live in Europe and we just came out of a freezing winter (unfortunately car stays outside the whole nights ) Could it be the air supply module that needs to be changed ?
My car is a 2014 TTS.
thanks for your help.
Old Jan 21, 2019 | 12:03 PM
paulbaj's Avatar
paulbaj is infamous around these parts
[QUOTE=Anthony997.2;4703568]
Hi guys,
I have the same issue. Did you get it sorted?
Old Jan 21, 2019 | 12:59 PM
Hi,
yes it got sorted sorted out by itself. This happened after I drove into some snow and ice so probably ice got trapped in one of the sensors in some way. When weather improved after some time the problem went away
Old Jan 21, 2019 | 03:46 PM
paulbaj's Avatar
Good to hear.
Old Jan 23, 2019 | 10:38 PM
longboarder's Avatar
This has happened multiple times on my car. The dealer keeps fixing it but the error message keeps coming back. Annoying but this has been the only issue in 3 years of otherwise completely reliable ownership so i cant really complain.
Old Feb 8, 2019 | 01:48 PM
k2man's Avatar
k2man is infamous around these parts
I had to have my front spoiler replaced because I ripped it on a curb. After installing the new parts, the dealer reprogramed it but the error message came back. After bringing it back they finally called Porsche NA and realized that there was some kind of software patch that was not installed (not sure if it was in the dealers equipment of the software in my car. If its not a mechanical issue, you might have your dealer call Porsche to make sure its not a software issue.
Old Feb 8, 2019 | 03:42 PM
Good info thanks!
Old Feb 9, 2019 | 02:39 PM
armana87's Avatar
armana87 is infamous around these parts
Had this happen several times, turned the car on and off sometimes still wouldnt work but after turning the car off, locking the doors and waiting about 10-15 minutes, works again. I am 100% certain this is a software issue.
Old Feb 16, 2019 | 11:52 PM
Ansari991tts's Avatar
Ansari991tts is infamous around these parts
Check with your dealer on the Dynamic Compressor there might be a leak for aero dynamic. I had the same issue before i changed the compressor and now no issues. Cost around $900-$1000 USD
swampydrill
Mar 22, 2021 10:05 PM
Koby
Nov 9, 2009 07:35 PM
Triple B
Cayenne 955/957
Jun 8, 2009 12:56 PM
HWJunkie
May 3, 2007 08:16 AM
