991.1 Turbo DIY Oil Change Video
Hi all,
I just uploaded the video of my Porsche 911 (991) Turbo Oil Change DIY. It was very easy to do, takes about 30-40 minutes from start to finish. There are some info out there on the regular 991 but none on the Turbo. Like most people have mentioned, its about the same. But if you're like me, you want to know for sure that this is for your car, check out the video.
My 991.1 Turbo took a little over 7.5qts from full oil drain to filling to 2nd bar from the top in the oil level display. I recommend filling to about the same and driving the car easy to verify the oil level. Add more if you're a tad low. Go with the lower side and add, its better than overfilling and having to take some out. Check out my video below and subscribe for more Porsche 991 DIYs and just all car videos in general.
Here are a few links to what you'll need:
0W40 Synthetic Oil: https://amzn.to/2uisg6V
36mm Socket for Oil Filter: https://amzn.to/2JnxhA4
Hex Socket for Oil Drain: https://amzn.to/2ma4UMm
Oil Filter Kit (o-ring and washer included): https://www.suncoastparts.com/product/PK997POINT2.html
I will when I change mine
Which will likely be in fall or winter depending on how nice the summer is.
pgunz
Feb 25, 2009 04:44 PM
bond
Jul 15, 2004 12:59 AM
