Base 991 Sports Mode does what?
Old Jan 17, 2013 | 02:41 AM
frenzy's Avatar
frenzy is infamous around these parts
What does the "sports" mode button on a base 991 with PDK and NO OTHER option do?
There is no PASM, PTV, etc to activate like on a S.
Does it simply just relax the traction control?
Old Jan 17, 2013 | 06:39 AM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
It does the same thing as the S, but the S comes with more things to adjust. In the case of a base with absolutely nothing on it, the throttle / shift scheduling is changed as well as disabling of the sailing and autostop functions. BTW I would think that would be a rather rare beast.
ChuckJ
Old Jan 17, 2013 | 07:01 AM
certified_prime's Avatar
certified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of light
I have a manual with no options.
For me, Sport Mode:
* Cools the engine oil further (225F in normal mode, 200F in Sport mode)
* Turns off auto start/stop
* Turns off the dummy upshift light
* Enhances throttle response
* Exhaust sounds more aggressive when applying throttle
* Increases fuel consumption (I drop several MPG. I don't exactly know why, likely due to throttle and extra effort to run the oil cooling fans)
Old Jan 17, 2013 | 09:20 AM
m5_2010's Avatar
m5_2010 is just really nicem5_2010 is just really nicem5_2010 is just really nicem5_2010 is just really nice
For me, Sport Mode:
You are correct. I doesn't do anything for me either....
Old Jan 17, 2013 | 09:35 AM
trysixty's Avatar
trysixty is a name known to alltrysixty is a name known to alltrysixty is a name known to alltrysixty is a name known to alltrysixty is a name known to alltrysixty is a name known to all
sure sounds alot better on upshift/downshift
Detroit Shooter's Avatar
Detroit Shooter is infamous around these parts
With PDK it changes the shift characteristics also it will shift harder in auto or manual. In auto the up and downshift points are changed dramatically. It will hold a gear before up shifting if you let off for example expecting you to get back in it any second.
With sport plus button pushed it becomes another car all together. The auto shift points are really only good for the track. The shifts can only be described as violent. The engine reacts more aggressively also in a way I find hard to describe.
I know you did not ask about sport plus but I find myself in normal mode cruising or sport plus in manual mode cranking on it. Sport plus in auto is hard to use on the street unless you are losing your mind and really cranking it up.
Old Jan 17, 2013 | 09:48 AM
spot on!
Oddly enough, that darn dummy light in Normal mode really annoys me. It is constantly on above 1500 rpm. It is just a small triangle, but half the time I engage Sport Mode JUST to get rid of that darn annoying triangle.
Old Jan 17, 2013 | 10:01 AM
rnl's Avatar
rnl
rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !
spot on!
no normal light here....when sport is engaged the word "SPORT" appears....
SPORT also changes the downshift patterns..if you quickly go from gas to brake it downshifts.
Old Jan 17, 2013 | 10:21 AM
19hole's Avatar
19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of
spot on!
You can completely disable the upshift triangle in the PCM options.
Old Jan 17, 2013 | 11:37 AM
I must do this. Which option is it under?
Old Jan 17, 2013 | 01:44 PM
frenzy's Avatar
Thanks for the replies!
So consensus it doesn't do much, especially if you run it in manual PDK. I'm surprised about the oil temp dropping though.
ChuckJ: yep, I finally found a low optioned PDK. lot car with PDK + sports steering which is all i wanted. Had a few non performance extra which i could of done without or traded it all for lower price or sports chrono, but i digress.
Old Jan 17, 2013 | 01:58 PM
Why? Under normal mode, the car allows the oil to run a bit hotter. Supposedly it is better for emissions and MPG, but I don't know why.
Under Sport mode, it runs the oil thru the intercooler all the time, and keeps it at a lower temperature...to compensate for more aggressive driving and better protect the engine at high RPMs.
Old Jan 17, 2013 | 08:05 PM
frenzy's Avatar
surprised since it sounds like it can route some/all oil through the coolers, shouldn't it always automatically do that in any mode regardless of sport or normal. Just keeps the car running at the optimal oil temp. otherwise, if i run really aggressive in normal mode, the oil temp is going up.
Old Jan 18, 2013 | 06:54 AM
Dadz911's Avatar
Dadz911 is infamous around these parts
It just makes the car that much more fun to drive at a push of a tiny little button. I was very surprised at how noticeable it was.
Old Apr 7, 2014 | 07:44 PM
hawc's Avatar
hawc has a reputation beyond reputehawc has a reputation beyond reputehawc has a reputation beyond reputehawc has a reputation beyond reputehawc has a reputation beyond reputehawc has a reputation beyond reputehawc has a reputation beyond reputehawc has a reputation beyond reputehawc has a reputation beyond reputehawc has a reputation beyond reputehawc has a reputation beyond repute
Originally Posted by ChuckJ
In the case of a base with absolutely nothing on it, the throttle / shift scheduling is changed as well as disabling of the sailing and autostop functions. BTW I would think that a base 991 with PDK and NO OTHER option would be a rather rare beast.
That's what I ordered. A 991 3.4 PDK with no options (except 20" wheels.)
Is it possible to program the car to have the Sport button on by default if it's so obviously a better state to have it in? Does it have to turn itself off each time you turn the car off?
