Cold engine noises and other annoyances
Old Oct 24, 2013 | 11:23 PM
2cardinalalums's Avatar
2cardinalalums is infamous around these parts
I took factory delivery of my 991 C2 7MT over the summer and the car ran perfectly in Europe. Once received stateside, a few things have bothered me:
1) passenger side window needs adjustment. it keeps thinking it hasn't reached the top when it has and then proceed to engage pinch protection and goes back down halfway.
2) still under 2k miles, so I try to upshift around 4k rpm. When I depress the clutch above 3k rpm, sometimes I hear a metallic engine fluttering sound.
3) When I start from 1st gear, I can hear a hum until I fully release the clutch
4) when the engine is cold there is frequently a clicking noise. I have an audio file of a recent recording on a morning start after I was away for a week. Usually it's not as loud or complex of a noise (more of a simple click). 6speedonline wouldn't let me upload the .MP3 file. any suggestions on how to share?
Could the cold engine click noises be caused by the lower octane fuel in USA? Any ideas on any of them? I'd like to avoid taking it back to the dealer. All are annoyances and not major, but still...
Old Oct 25, 2013 | 12:41 AM
studlee's Avatar
studlee is infamous around these parts
i just hit 2k miles and recently noticed the metallic fluttering noise as well.
Old Oct 25, 2013 | 07:06 AM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
Old Oct 25, 2013 | 11:01 PM
Originally Posted by dux
Thanks! I'll give this a try.
Old Oct 25, 2013 | 11:02 PM
How frequently does it happen on yours?
Old Oct 27, 2013 | 07:39 AM
chance6's Avatar
chance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to behold
I've heard the clicking noise on mine too...it's faint...but it's there.
Old Oct 27, 2013 | 10:31 AM
studlee's Avatar
when im shifting at higher rpms. it almost sounds as if this is the noise that gives the pse exhaust that burbling sound, but i dont have pse exhaust. i'll drive it around and see at what rpm and report back
Old Jan 19, 2014 | 12:01 AM
studlee's Avatar
i have about 3800 miles now. i have noticed at about 3800-4000 rpm the metallic sound when i let off the throttle.
Old Jan 19, 2014 | 08:47 AM
lunarx's Avatar
lunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to behold
I get a metalic sound with rapid acceleration on-throttle.
I suspect the exhaust is thin walled and vibrates a lot.
or
Something is loose and moving around.
I plan to schedule a dealer visit to have them tighten/adjust the exhaust.
Old Jan 19, 2014 | 09:29 AM
CarreraPete's Avatar
CarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud of
I did notice the metallic fluttering sound on my early 2013 991S manual. I had traded it in for my latest 991S manual which is a May build (don't ask) and, although I do hear the fluttering sound at times, it's not as pronounced as it was on the first car.
I had also corrected the window problem by following the information in the provided link.
I tend to believe that the fluttering sound may be coming from the exhaust system. I did notice that the exhaust note became louder when I reached approximately 1800 miles on the clock.
Old Jan 19, 2014 | 02:48 PM
I tried rev'ing the engine in neutral and I never hear the metallic fluttering sound, so I'd guess it isn't the exhaust. I hear the sound only when I [ress down on the clutch with the RPM above a certain level.
Old Jan 20, 2014 | 01:23 PM
TRM's Avatar
TRM
TRM is infamous around these partsTRM is infamous around these parts
You guys sure the metallic fluttering sound isn't pre-detonation? Looking at the last response it wouldn't happen in that case (revving in Neutral), only likely under acceleration in gear and moving.
Just thinking out loud on this one.
Old Jan 20, 2014 | 01:45 PM
Christophosphorus's Avatar
Christophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to behold
3) I hear the humming noise on cold starts. After about 20-30 seconds, the 1st-gear hum goes away. I've been in another 991 from the factory that did this on a cold start.
4) Been told that this is *somewhat* normal for our engines, especially on cold starts. With the lifters being positioned as they are, the engine is noisy until the block/oil heats up. I know exactly what you're talking about… it's a very clear, ticking sound. You may want to have the dealer check it out if it's extremely loud.
Old Jan 20, 2014 | 11:29 PM
I don't think so. I'm pretty sure it is not pre-detonation.
Old Jan 20, 2014 | 11:32 PM
That's good to know on #3. I'll see if mine is also gone after the car warms up. For #4, I did take it to a dealer. We tried a couple of other cars on the lot. Mine is louder, but they all made the ticking sound. I definitely did not hear the ticking sound when I drove it during euro delivery (mild summer weather and had the windows down frequently.)
