Intermittent no heat
Old Nov 10, 2013 | 09:19 PM
SxxB's Avatar
SxxB is infamous around these partsSxxB is infamous around these parts
Sometimes my hvac would not produce any heat. One time restarting the car did the trick but other times not. It could cut the heat for 1/2 hour, or work for 40 min and then cut out for good. I'm afraid that when I take it to the dealer it will be a waste of time because my hvac will be on its best behavior at the time.
Anyone else had issues with intermittent no heat? If so, what was the fix?
Old Nov 11, 2013 | 08:16 AM
JamesKen's Avatar
JamesKen is a glorious beacon of lightJamesKen is a glorious beacon of lightJamesKen is a glorious beacon of lightJamesKen is a glorious beacon of lightJamesKen is a glorious beacon of lightJamesKen is a glorious beacon of light
I would do a search. I have read numerous posts about this.
Old Nov 23, 2013 | 08:09 PM
JonnyC's Avatar
JonnyC is infamous around these parts
Heater fix
I had the same issue. At first, the dealer (Porsche of Conshohocken) couldn't replicate it, and "recalibrated" the climate control system, which didn't fix the problem. Two days later (as the weather turned colder near Philadelphia), the dealer said lots of cars suddenly had the same problem, and they learned from PCNA that there's a replacement part for a solenoid/valve that fixes the issue. The new part was installed in my car and the heat is working fine.
Old Nov 23, 2013 | 08:21 PM
SxxB's Avatar
Just picked up my car and indeed, the dealer replaced some valve and it's working now
Old Nov 24, 2013 | 10:03 AM
jnscolo's Avatar
jnscolo is a name known to alljnscolo is a name known to alljnscolo is a name known to alljnscolo is a name known to alljnscolo is a name known to alljnscolo is a name known to all
Guys,
What MY cars have this issue?
TIA
Old Nov 24, 2013 | 10:10 AM
dyim's Avatar
dyim is infamous around these parts
Originally Posted by jnscolo
Guys,
TIA
My exact thought. Build date of affected cars?
SxxB's Avatar
Guys, What MY cars have this issue? TIA
Mine is model year 2013 ( nov 2012 build )
Old Nov 24, 2013 | 10:41 AM
STALKER's Avatar
STALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to behold
This is good to know.
Mine tends not to heat up unless I crank up the temperature. Taking it in next week.
Old Nov 24, 2013 | 04:37 PM
kev_song's Avatar
kev_song is infamous around these partskev_song is infamous around these parts
I have the same problem. But I found if your turn off the ac via the ac button and turn it back on the heat will come on. I complained about this a month or so ago and they didn't have a fix then. Will have to take it back in
Old Nov 24, 2013 | 05:49 PM
JonnyC's Avatar
Mine is a 2013, with a build date in May or June of 2013.
Old Nov 24, 2013 | 07:37 PM
dyim's Avatar
Hmmm, mine is built between these two. Need to find a cold dry day and take it out to see. Thanks for the response.
Old Nov 26, 2013 | 04:15 PM
pleahy's Avatar
pleahy is infamous around these parts
I am having same intermittent heat issue in my '13 C4. It is unpredictable, and I've tried every trick I can find w adjustments on the console with no avail. I took it in today and they could not reproduce it, unfortunately. So, a software update and "hard reset" of the system hopefully will help. I learned that if the dealer cannot find a faulty part under warranty, there isn't a lot they can do.
Old Nov 26, 2013 | 04:23 PM
jj911c2's Avatar
jj911c2 is infamous around these parts
Same issue for me (2012 MY) and I took it to dealer but they could not replicate it.
Old Dec 2, 2013 | 08:50 PM
maxboost's Avatar
maxboost is infamous around these partsmaxboost is infamous around these parts
Same issue here....dealer had this happen with another car..preordered part(check valve) and installed and no more issue.
Old Dec 3, 2013 | 12:41 PM
m5_2010's Avatar
m5_2010 is just really nicem5_2010 is just really nicem5_2010 is just really nicem5_2010 is just really nice
They changed the heat exchanger located in the back with the engine... My heat had stopped working...
