Spare tire options or possibly purchase 20" wheel/tire if it fits in frunk
Old Dec 29, 2013 | 12:41 PM
af330i's Avatar
af330i has a spectacular aura aboutaf330i has a spectacular aura aboutaf330i has a spectacular aura about
I have a 2012 991S for over a year and half and I decided it is time to explore my spare tire options again ... especially since there are a lot more 991 owners out there now.
I have posted in the past and it seems the only option I found was for $1295. at Suncoast.
http://www.suncoastparts.com/product...HASSISWHEELACC
Has anyone come up with any other solution ... Another thought was to get a wheel and tire from tirerack for under $700 and keep in it in the frunk but I don't know if a 20" wheel/tire uninflated would fit.
Thanks for any advice you can offer.
Old Dec 29, 2013 | 04:21 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Would a spare from a 996 or 997 work?
Old Dec 29, 2013 | 11:16 PM
lunarx's Avatar
lunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to behold
Best option is a plug kit.
Although HRE can make you a skinny spare wheel for a skinny tire that matches the diameter of your rear tires.
Find the tire and then get the wheel made.
Only real concern is getting the offset right to clear the calipers.
Old Dec 30, 2013 | 08:39 AM
Snowczar's Avatar
Snowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to behold
Almost certainly the 996 spare won't clear and I doubt the 997 would either.
Old Dec 30, 2013 | 11:11 AM
af330i's Avatar
I have a spare that was for my 997 (it was from a Boxster) and I believe it was too small ... I still have it and will re-check it but I am pretty sure I exhausted that option when I first got the car.
Thank you to the others for the suggestions, currently I do have a plug kit in the car.
As far as HRE making me a wheel, that is a really interesting idea and I will see if they are able to do so.
Old Dec 30, 2013 | 11:36 AM
rnl's Avatar
rnl
rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !
The thought of no spare tire alarmed me when I purchased the 991. Now, upon reflection and 18 months of ownership, it's not a big deal. So far, so good and come to think of it, I have not had a tire problem or fl@t (i am not going to even type the word) on any car that I can recall.
Old Dec 30, 2013 | 06:19 PM
lunarx's Avatar
The skinnyest 19" tire I can find with the right [27"] diameter is a 225-45-19.
It requires a min 7" rim to mount it.
You can get it in a Y speed rated PSS, S-04, V12, so you would not even have to slow down when using it
HRE can build you a spare wheel, for that tire, that can clear the calipers.
I had them make a matching spare, for a car I had before with HRE's on it.
Question is, can it fit in the Frunk or on the Rear Shelf
You would have 27"d and 8.7"w (on a 7" wheel).
Old Dec 30, 2013 | 06:26 PM
gtr's Avatar
gtr
gtr has a spectacular aura aboutgtr has a spectacular aura aboutgtr has a spectacular aura about
I just want to let Porsche know that I would still be driving a Porsche if the new models offer a spare option. This doesn't mean I will not buy one as a weekend car but a spareless daily driver without RFT does not make sense to me. For the people wiling to spend the $$ why cut cost?
That suncoast option is great but looks horrible and it look like you can't tilt that passenger seat back. There is gotta be a better solution?
Old Dec 30, 2013 | 06:32 PM
lunarx's Avatar
That suncoast option is great but looks horrible and it look like you can move that passenger seat back. There is gotta be a better solution?
You could put Run Flats on it if you want, it would be perfectly fine to do.
Most people don't like their ride quality though, which is why manufactures are reluctant to make them their "standard" tire.
Old Dec 30, 2013 | 09:24 PM
991TurboS's Avatar
991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light
Doesn't your car have the fix a flat repair kit with the air compressor. I thought that came on all 991s?
Old Dec 31, 2013 | 04:55 AM
trysixty's Avatar
trysixty is a name known to alltrysixty is a name known to alltrysixty is a name known to alltrysixty is a name known to alltrysixty is a name known to alltrysixty is a name known to all
I went the way Rainer did in this post. Bought just the spare wheel and tire from Sunset Porsche in Portland for about 600, then went to auto store to get the rest of the kit that Porsche charges 10x too much for. Although I don't drive in South Africa like Rainer.........it can get pretty desolate traveling in eastern Washington. We have a lot of cougars here, no lions though
https://www.6speedonline.com/forums/...ire-991-a.html
ModBargains
Aug 20, 2015 12:28 PM
pwdrhound
Aug 20, 2015 05:54 AM
