not sure if this is a problem or not...
Old Jan 30, 2014 | 05:53 PM
JMMB 911's Avatar
JMMB 911 is infamous around these parts
I live in NYC and we have been having a brutal winter... car is a 2014 C4S and when its really cold outside i notice when i turn the steering wheel all the way, my front wheels hop and slide. I do still have summer tires on the car and i'm thinking thats the issue, but not 100% sure.
Old Jan 30, 2014 | 05:55 PM
Dilligaf's Avatar
Dilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to all
Not a problem, normal and well documented
Old Jan 30, 2014 | 06:24 PM
SLATETT's Avatar
SLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to behold
I believe mine does this too
Old Jan 30, 2014 | 06:44 PM
fastmd's Avatar
fastmd is infamous around these parts
That's the issue, put winter tires on and it will go away.
Old Jan 30, 2014 | 07:25 PM
Fester's Avatar
Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !
No worries --summer tires reacting as designed
Old Jan 31, 2014 | 06:21 AM
plenum's Avatar
plenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant future
Yeah +1 above comments. I have a 14 C4S and as soon as the temperature was in the 40s and lower consistently I had the same experience. I switched to a new set of winter tires and the feeling when turning the wheel sharply in the driveway was much much better. As mentioned by others, this is something well documented on this and other forums. Nothing you need to worry about....
Old Jan 31, 2014 | 07:46 AM
MikeDi's Avatar
MikeDi is infamous around these parts
Yep. Same here. Scared me the first time it happened.
Old Jan 31, 2014 | 10:08 AM
handfull's Avatar
handfull is a splendid one to beholdhandfull is a splendid one to beholdhandfull is a splendid one to beholdhandfull is a splendid one to beholdhandfull is a splendid one to beholdhandfull is a splendid one to behold
Not a problem, every car I've owned that had high performance tires does the same thing when temperature drops.
PV=nRT.
Sep 9, 2022 06:06 PM
cockneymike
Oct 22, 2015 06:00 PM
vogz
Sep 19, 2015 01:02 PM
nal991
Sep 11, 2015 09:05 AM
flewis763
Sep 10, 2015 01:08 PM
