Difference between base and S?
Old Oct 3, 2016 | 07:06 AM
MrPorsche's Avatar
MrPorsche has much to be proud ofMrPorsche has much to be proud ofMrPorsche has much to be proud ofMrPorsche has much to be proud ofMrPorsche has much to be proud ofMrPorsche has much to be proud ofMrPorsche has much to be proud ofMrPorsche has much to be proud of
What do I get for 15K extra going from a base to an S model.
I'm looking into a 4S cabriolet and wondering what I'm getting for $15K
I see 50 HP difference and 37 ft lb of torque. That doesn't seem like I'm getting much for 15K. Sometimes they sneaky in other options though like the letter "S" and cooler rims? What else do I get?
Old Oct 4, 2016 | 06:47 AM
grover432's Avatar
grover432 is infamous around these parts
Check out the Porsche website for all the details but you get 20" wheels standard, extra power, larger brakes and access to options not available on the base (rear wheel steering, -20mm SPASM, etc )
Old Oct 4, 2016 | 08:59 AM
Tim1137's Avatar
Tim1137 is infamous around these parts
I believe the S has 0.4 liters of extra displacement as well (3.8 liter versus 3.4 liter) It may not seem like much, but that helps power over the whole rpm range, torque, turbo response etc.
You can always buy a Cobb Accessport for your Base model though and get that power for $1295 dollars instead of 15K hahaha
Old Oct 4, 2016 | 01:28 PM
grover432's Avatar
They are both 3 litre engines
Old Oct 4, 2016 | 10:10 PM
ronglos's Avatar
ronglos is infamous around these parts
Don't forget the red calipers.
Old Oct 5, 2016 | 05:35 AM
grover432's Avatar
I don't really consider that a real difference - can be fixed with a can of red spray paint.
Old Oct 5, 2016 | 07:35 AM
ronglos's Avatar
I've thought of that but will it hold up for long? Doesn't the factory powder coat them regardless of color?
Old Oct 5, 2016 | 08:20 AM
grover432's Avatar
Maybe, but lots of guys take theirs off and redcoat them in a different colour. I wouldn't, but some people do stuff like that and then change the model plate on the back of the car too. I think the OP just wanted to know what the differences in opts were between an S and non S. I think my above post covers it, plus the red callipers. In addition, the base car comes standard with 19's and the S models come standard with 20's
Old Oct 5, 2016 | 09:09 AM
kabob's Avatar
kabob is infamous around these parts
You can get calipers powder coated anywhere at many metal coating or refinishing shops.
Old Oct 5, 2016 | 05:38 PM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
Does anyone know if there's any difference in engine internal and auxiliary (turbo's) components?
Old Oct 5, 2016 | 06:05 PM
MrPorsche's Avatar
I thought the engine was identical, and the circumference of the turbo was slightly larger.
The red calipers represent more brake cylinders.
Old Oct 6, 2016 | 09:10 AM
grover432's Avatar
I don't think disk brakes have brake cylinders. Drum brakes do though.
Old Oct 6, 2016 | 09:11 AM
grover432's Avatar
Turbos are different offering more boost than the base car. Engine tuning is adjusted.
Old Oct 6, 2016 | 03:51 PM
MrPorsche's Avatar
Sorry, pistons.
Old Oct 6, 2016 | 04:13 PM
grover432's Avatar
Sorry, pistons.
I was just having fun with you.
