Auto start stop function not working
Old Dec 18, 2017 | 01:16 PM
cclcal's Avatar
cclcal is infamous around these parts
Hello all
Im new here. Just received '13 S model.
Im aware of the dislike of the feature but just wanted to see why it's not working. I've had it work on a '13 cab but cannot get it to work on my car.
Yes, ive met all the requirements, AC off, live in San Diego...
Engine remains on regardless of start stop button on or off. The symbol does light up on dash w 3 dotted lines under it, as well as the one w the diagonal line going thru it.
Is there a fuse replacement or simple fix for this?
thanks!
craig
Old Dec 18, 2017 | 01:29 PM
PorscheCrazy's Avatar
I'm no expert on it, but I believe that there are some variables that will prevent it from turning off and on, one of which is if the battery is weak or under heavy load. Also, will not work if you are in Sport mode or if you don't have seat belt on. There may be other conditions too - read the manual.
Old Dec 18, 2017 | 01:42 PM
cclcal's Avatar
I read the manual, those requirements are interesting....not in sport mode, seat belt on...the only thing is I haven't checked the battery
Old Dec 18, 2017 | 01:49 PM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
It will come on (or not) under a very specific set of circumstances.
Battery charge, engine temp, ambient temp, battery load etc etc.
I thought the same thing at you, until one day after a long drive on a relatively cool day it kicked in and worked as intended.
Old Dec 18, 2017 | 02:08 PM
cclcal's Avatar
thanks!
ill play with it
Old Jan 11, 2018 | 05:28 PM
sanjeev's Avatar
sanjeev is infamous around these parts
more info on auto start stop
Hello all,
I too have wondered about this, since it doesn't seem like its obvious when it will work repeatedly or not. Having paid attention to it now for ~1 year (4 seasons), I've noticed the following:
- the engine has to be at operating temp, and it is not too cold outside. Note, during the winter around here, it takes a good 20 mins/15 miles+ for both the water and oil temps to reach operating temp.
- there appears to be some correlation with the recent drive cycle history. If the car is being used for many short trips (less than 20 mins?), I've noticed that start-stop becomes less frequent or likely to activate. However, after a longer drive (say a highway drive), it becomes very active. I suspect this has to do with programming which assures the combustion chamber is relatively clean, as would happen after a long highway drive.
Would be curious as to whether others have observed similar patterns.
- Sanjeev
Old Jan 11, 2018 | 07:01 PM
Porschejeff's Avatar
Porschejeff is infamous around these parts
Be happy it doesn't work. I hate that function on my car.
Old Jan 11, 2018 | 07:56 PM
chance6's Avatar
chance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to behold
One key for mine is that the car has to be fully warmed up. Coolant and oil temps. Porsche is careful about restarting engines with lower oil temps.
Old Jan 11, 2018 | 08:29 PM
cclcal's Avatar
ok so im 100% sure ive met all the requirements as stated in the manual. Not on Sport/Sport+ mode, car is warmed up, etc.
Went to get battery tested, its a perfect 12.47 V.
So why doesnt Auto Start-Stop work? I have no clue. I thought maybe a fuse? However, the "A" w yellow circle does show up on my dash indicating Auto Start-Stop not working so not sure it's a fuse issue.
Like PorscheJeff said, not a big deal since it's not a significant function. I would just like all things to work on the car even if would never turn it on.
any other hints?
Old Jan 12, 2018 | 04:04 AM
Weird - if you followed all requirements and battery is good, no idea what could be wrong. I'd suggest taking car in to dealer for checkup.
Old Jan 12, 2018 | 12:19 PM
cclcal's Avatar
yeah, ill prob give the dealer a call or my local indy. but i may just save the diagnostic $ since I may not use the feature anyways....
Old Jan 12, 2018 | 01:31 PM
runner1021's Avatar
runner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to behold
My guess is that you're above 9850 ft., or your windshield defrost is active.
Just two of the instances where *** is disabled. Description begins on pg. 46 in the link:
https://www.dropbox.com/s/vkmowmu127...20SIT.pdf?dl=0
Old Jan 12, 2018 | 01:41 PM
cclcal's Avatar
hey thanks for the infobut unfortunately im down here near sea level in San Diego and defrost is not on....
Old Jan 12, 2018 | 02:12 PM
solipsistik's Avatar
solipsistik is infamous around these parts
First thing I ever do is put my car in sport mode when I start it. I use normal mode only on highway drones, and when I either turn off auto stop or put it in sport mode when I am in an area with stops. If I could, I'd turn it off permanently. Hate.
Old Jan 15, 2018 | 01:13 PM
steve-t's Avatar
steve-t is infamous around these parts
I
I experienced the same thing with my 2012 sI brought it to be checked twice both times they told me it was ok. Then I let them keep it overnight and they determined it was the battery even thought it checked within spec. They replaced the battery and it has worked normally since
