993 Turbo This community is about the last air cooled twin turbocharged Porsche 911. Model year 1996 - 1997. Also inclusive in this forum is talk on the final 182 Porsche 911 Turbos built in 1997 known as the Turbo S.
1996 993 turbo smoking problem
Old Mar 28, 2010 | 11:09 AM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
A friend of mine is suffering from excessive engine smoke when starting the car after a stop period of two days, it stops smoking after around 3 minutes after starting, he has an exhaust system don't know which brand, fvd turbos, fvd tune, 5 bar fpr, fvd diverter valves, bmc filter, please share your opinions, what could be the cause of this, no one knew the cause of this neither fvd or the dealership, please help.
Old Mar 29, 2010 | 03:49 PM
RSS's Avatar
RSS
RSS is a name known to allRSS is a name known to allRSS is a name known to allRSS is a name known to allRSS is a name known to allRSS is a name known to all
Did your friend have a recent oil change? It sounds like somehow they are getting oil in their turbos and it takes 3 minutes to blow it out?
Old Mar 29, 2010 | 09:50 PM
jalmood's Avatar
Not recently no, but the turbo oil lines has been replaced recently thinking that it was the cause, the engine has been lowered in a recent ocassion in order to find out the problem but no use. And yes it does smoke that bad (2 to 3 minutes) if its parked more than one day, heavy smoke.
Old Mar 30, 2010 | 11:55 AM
RSS's Avatar
RSS
Old Mar 30, 2010 | 12:16 PM
jalmood's Avatar
Thanks for the link, will read through it and hope that i find an answer.
Old Mar 31, 2010 | 12:17 AM
K24madness's Avatar
K24madness is infamous around these parts
I doubt it's the turbos. Have him change the oil and not tighten the filters to much. I installed 996 check valves to eliminate the worries.
Old Apr 20, 2010 | 06:52 PM
LT1's Avatar
LT1
LT1 is infamous around these parts
make sure the oil filters are porsche. I had the smokescreen problem once when my wrench used replacements
Old Apr 20, 2010 | 08:28 PM
turtle n hare's Avatar
turtle n hare is just really niceturtle n hare is just really niceturtle n hare is just really niceturtle n hare is just really nice
Could it be that a ring let loose?. If I dont drive my Porsches for months it will do that too, but for a short period of time, that seems awfully odd.
Old May 10, 2010 | 05:29 AM
jpc's Avatar
jpc
jpc is infamous around these parts
I had a similar problem on my 993TT 3 years ago
My car had very low oil consumption before and it did not even release a puff of smoke after 3 weeks of standstill.
then suddenly it developed this problem. Every day i started it, huge amounts of blueish smoke came out of the exhausts and this continued for at least 10 minutes after driving off.
The longer it had stood stil, the worse the smoke was and the longer it persisted
After a lot of searching and calling around with colleages, my mechanic was given a solution by one of them.
He installed the valves in the upper oil lines of the turbos, similar to those that are standard in the 996 turbos.
After 2 years and 5000 miles, the car had not realeased a single puf of smoke again, not even after hard driving or longer periods of standstill.
Hope this helps
Perkman87
Nov 19, 2015 05:31 PM
PelicanParts.com
993 Vendor Classifieds
Aug 20, 2015 03:08 PM
PelicanParts.com
993 Turbo Vendor Classifieds
PelicanParts.com
Aug 18, 2015 03:55 PM
PelicanParts.com
