996tt. Need lug-nut info and jack info
2003 996tt
Well, i am getting some track rims and tires, what do i need to know and have for swapping rims at a track ?
Recommendations for Torque wrench and settings/lbs ?
What size Lug Socket ?
Recommendation of Jack ?
Any tips along the way ....
Thx as always everyone !!
DW
DW
90 ft/lbs will do. 19mm lug socket. I used the stock repair kit jack
for a long time. (easy to carry, very light etc) For a home jack, the
low one from Griot's Garage is *very* nice. It goes under a lowered
car, and lets the car down gradually. Others will drop it like a stone
unless you're very careful.
http://www.griotsgarage.com/catalog.jsp?&SKU=77739
A rechargeable impact wrench is very nice for undoing the
lugs, and for *gently* retightening. You don't want to tighten
more than finger-tight with it. Let the torque wrench do that.
I use a 12-volt DeWalt with a long socket. Plenty enough torque
and not too much to risk overtightening.
Last edited by Joe Weinstein; Oct 5, 2007 at 01:18 PM. Reason: give correct socket size
why scary "oak" ?
thanks Joe !!! glad to hear the info, i am heading to Napa tomorrow for a bunch of stuff, i will have to add this to my list and i guess i will check out home depot for the impact dewalt.
DW
DW
i'll second joe's comments. i though like to make it easy on myself... so with that said...
i have a racing jack
I have a snap-on impact cordless drill (a real pleasure)
a round chair to keep me comfy.
ahh... a chair ! acutally that would be useful ! okay, i went to pepboys and napa. took a print of this info. jacks are like $200, wrench about $70. Didnt see a drill, maybe i will just use the torque wrench for a few times. Is a torque wrench too delicate to use for removing bolts? i mainly see people use them to do the final touch..
Excellent tips by Joe. I used almost the exact same techniques a fwe weeks ago when I wanted to really clean the inside of the wheels and the wheel wells. It is really easy to do, also remember to use the long threaded "pin" in your spare tire kit to screw into one of the lug hoes. This will make lining the tires up very easy on reinstall.
I first torque to 60 ft lbs on the first past in a crossing star pattern and then 96 ft lbs to finish. The socket is 19mm or 3/4 inch in a pinch. I use a standard 2-1/4 ton jack with a special plate that has a protrusion on the top that looks like the nub on the OEM jack from the trunk. To jack the vehicle I first drive the car up on spacers. They just small ramps made from 2" x 6" lumber about 12" long with a 45 degree chamfer on the drive up edge. From there I jack the car up using two floor jacks in the back. Install the jack stands and then do the same to the front. Lowering is just the revers order...
Cheers,
Cheers,
PelicanParts.com
Aug 28, 2015 12:53 PM
