2004 Build Quality: TT CAB vs Boxster
Old May 19, 2004 | 11:57 AM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
I just took my car in for the xth time and got a Boxster loaner car.
The Boxster has zero rattles and zero squeaks... and is a lot of fun to drive because of it.
My TT Cab has more rattles and other noises than any of the six previous 911 Cabs I have owned combined.
Could it be that the Finish - they make the Boxster - are better Porsche builders than the Germans? Or have all the seasoned Porsche builders been pulled over to the Cayenne line?
Old May 19, 2004 | 12:45 PM
TUUNER's Avatar
TUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant future
You know, it's interesting. My TT coupe makes more sounds than any other car I've ever had. Most other TT owners I've spoken with also comment on such sounds. Based on what I've read and heard, it's very common and most of the time you will have a very, very difficult time pinpointing the source of the sound.
Part of the TT mystique I suppose. I like Arlings suggestion that as long as the car drives well, it can make all the noises it wants!
Also, keep in mind that most cabs tend to make more sounds than coupes due to the rigidity of the vehicle. Had the same issue with my M3 cab (lots of creaking when taking turns, etc). Supposedly the rigidity on the TT Cab is supposed to be very good.
T
Old May 19, 2004 | 01:43 PM
SilverTTCab's Avatar
Senior Member
SilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud of
i started to notice today some creaks - plastic sounding creaks.
especially when i'm pulling out of the drive way...
hmmmm... hop ei don't fixate on it forever...
Old May 19, 2004 | 09:54 PM
MKW's Avatar
MKW
MKW is infamous around these parts
I think it's random. My TT has no creaks or squeaks , but the service loaner Boxsters I've driven have made lots of groaning roof noises and had interior squeaks .
Old May 19, 2004 | 10:00 PM
MANA's Avatar
MANA is infamous around these parts
Mine is noisy as well. Mostly with the top up. I do have an extremely annoying metalic buzz coming from either the drivers side of the dash or the drivers door. Sounds like a small metal clip vibrating. Not really loud but it bugs the crap out of me.
Old May 19, 2004 | 10:22 PM
AeroTT's Avatar
AeroTT is infamous around these parts
Install a Europipe or Fabspeed Stage 2 Loud exhaust and I guarantee that you wont be able to hear any more of those annoying little sounds that you hear now!
Old May 19, 2004 | 10:46 PM
Benjamin Choi's Avatar
Benjamin Choi is infamous around these parts
Y'all need to let it go.
It's a piece of machine bolted together, glued together, welded together.
It's going to make noises.
Old May 20, 2004 | 12:12 AM
Control It's Avatar
Administrator
Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !
Maybe it is because the Boxster was designed from the ground up to be a convertible.
My Boxster is very tight and less noisey than the TT.
Love that cloud of oil on startup...warms the heart..
I can't believe how much oil these things burn..but it seems to be normal..
Mark
Old May 20, 2004 | 07:24 AM
ESK's Avatar
ESK
Hick from NH
ESK is infamous around these parts
I had awful squeaking noises when I first got my TT Cab. The sound was so bad it was as if the suspension was falling apart. I found that it was caused by the metal boot cover coming in contact with the cabriolet top. I was able to isolate the area (directly in the middle below the rear window) where there was rubbing and put a piece of black electrical tape on the bottom of the metal strip. This solved the problem.
Old May 20, 2004 | 07:55 AM
20C4S's Avatar
T
T,
this only allowed on PORSCHE
other bothered by the noise,
play ur music loud enough to cover the noise!
Old May 20, 2004 | 09:29 AM
JMT's Avatar
JMT
JMT is infamous around these parts
My TT has no creaks or squeaks. My old Boxter was a rattling piece of junk.
Old May 20, 2004 | 09:47 AM
Doug H's Avatar
Doug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud of
Would the suspension not be harsher on the TT?
Old May 20, 2004 | 09:54 AM
Control It's Avatar
Administrator
JMT, don;t hold back!
I love my Boxster S even more after getting the TT. Fun to switch on nice sunny days.
I also had a 99 Boxster. The S was a huge improvement.
joeyharp
Aug 29, 2016 09:41 PM
Socalsporty
Sep 9, 2015 10:07 AM
AdamNoone
Sep 3, 2015 04:15 PM
