70 or 75mm TB + Plenum worth in a 535 rwhp
Old Nov 20, 2007 | 07:38 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
Question 70 or 75mm TB + Plenum worth in a 535 rwhp
I just love how the EVO ICs work in my Stage 4 at 1.2-1.3 bar, much less lag and really sharp on the gas at low rpms.
Now, I am really temped to get the Plenum (70mm) but I have heard that a good up-grade will be a larger TB (75mm) with the Plenum for that.
I really do not want to increase lag ... and I want a bit more on the top.
Thus, does the 75 mm set up will be a good idea, worth and best bet?
Thanks!
Old Nov 21, 2007 | 09:31 AM
Question
anybody?
Old Nov 21, 2007 | 12:32 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
You cant really get much more on top without sacrificing a bit of spool up time. The 75mm wont give you much more lag, but you will gain a bit more on top. I say go for it.
Old Nov 22, 2007 | 12:48 PM
Thanks!
my goal is 555 rwhp 650 crank hp on K24's on pump gas
Old Nov 22, 2007 | 12:56 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
not worth it unless u tune for the change...
S
Old Nov 22, 2007 | 12:59 PM
Dont waste ur money....
If u really want to decrease lag and inprove Throttle response you should put on the intake from FVD( blue in color).. but that is not worth the $$$ spent at ur level either.
Take out 100 lbs. and you will have the same result as gaining 20 to 30 hp.
IF you want more power you need bigger turbos....
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 22, 2007 | 06:01 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Hmmm or just upgrade your turbos with 18 or 20g!!!!
Robert
Old Nov 25, 2007 | 08:58 PM
Thanks for your input!!
wrs
Nov 17, 2016 06:53 AM
White991TT
Mar 8, 2016 06:01 AM
30vQuattro
20
Dec 4, 2015 05:26 PM
freddiemac
Oct 7, 2015 11:05 AM
