Cold weather boost problem.
Hey fellas here's the deal I've got k16/24 on the car with stock waste gate spring and actuator. In the cold weather here in Indy the car is over boosting and hitting the throttle shut down (1.3 bar). I've backed down the threads a few times but it's still happening. Any suggestions?
Lee
Lee
The the drop in temps... are you sure u have stock WG springs?
2001 996TT 3.6L and stock ECU
I thought I did is if not what is the solution? Ebc? What is involved with an install?
Make sure that you are truly over boosting and this is not a plug issue (feel similar) additionally keep in mind the cooler the air gets (sea level) the more dense it becomes hence the ability to sustain more boost. The program should adjust for this unless the boost valve is weak or not working or the wastegates are too tight. How are you adjusting these? Do you know how many threads you have them preset??
If they were staying closed they would spool faster. Do you mean open? If you measure the ends (again not the best way to set up the wastegates) the threads should be apx 6mm and 8mm form the end for a near factory setting. You really need to use a gauge and bleed them off to set them. Make sure you do not have a leak to the valve. The hose does spli or come off. This would cause overboost as well.
Haha that's what I meant. This is 100% a cold weather issue. I've checked everything related and this only happens when its cold. Hey Stephen do you think the ecu should have been flashed for the issue? Should I consider a different flash?
sdg1871
Dec 24, 2015 12:22 PM
