Race Gas
Old Nov 24, 2007 | 10:43 AM
Christian's Avatar
Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !
Race Gas
When you guys use it, what octane do you use?
Do you wait until you are on empty to use Race gas or do you do half and half
Christian
Old Nov 24, 2007 | 11:01 AM
slant911's Avatar
slant911 is infamous around these parts
Christian I am NO racer but I use 50/50 all the time to raise the octane to around 94/95. That way my flashed ECU can take full advantage of the tune as possible. The couple of times I have gone to the track I've just put straight 100 octane in for the few weeks prior to the "event". I'm sure some 91 octane remains but so very little that the octane rating is very close to 100.
Old Nov 24, 2007 | 11:16 AM
PorschePhd's Avatar
Wait until the tank is damn near empty then fill it. Most programs are not desined to use a half mixture. If you were desinged to use 100 then you must have 100. Not half and half.
Old Nov 24, 2007 | 11:32 AM
mclaren55's Avatar
mclaren55 is infamous around these parts
I drain the tank and run C16. Ballin',
Old Nov 24, 2007 | 11:33 AM
PorschePhd's Avatar
C16 rocks! Crank that boost and crank that timing. The I can do no wrong gas!!
Old Nov 24, 2007 | 01:21 PM
oak's Avatar
oak
I always mix and there is quite abit of noticeable difference. w straight 91 I can feel timing cutting back way too early.
Old Nov 24, 2007 | 03:19 PM
slant911's Avatar
Yes the ECU even in stock form is made to run on 93 octane. There is no such animal in these parts of the country. 91 is the best you can get so I always mix with some 100 to get the octane up to where it needs to be even for Porsche's stock tuning.
For a while I ran straight 91 and you can REALLY tell the difference. Timing cuts back and boost gets limited.
Old Nov 24, 2007 | 03:43 PM
WOODTSTER's Avatar
Myself and S-351 keep the local VP Racing fuels distributor busy dropping of
Drums of MS-109 (103 octane unleaded) to our various locations. It is best to
run it straight like the good doctor says (If that is what your car is tuned for,
ie. race gas tune). It is between $9.5 and $9.90 a gallon delivered. He also uses
alot for his racing snowmobiles. I run it as straight as possible.
MK
Old Nov 24, 2007 | 04:16 PM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
MY CAR LOVES that ms109 stuff and yeah as pure as you can get it in the tank the better....BUT you know what.. even with a little mixture the car runs great... I did notice that running straight 118 didnt work as welll as 50/50 118 leaded with 94 unleaded.... who knows...why...??? but thats what my car likes...
Old Nov 24, 2007 | 04:18 PM
DMaffo's Avatar
HEre the 5 gallon container from VP is $86 !!!!!!!!! YIKES!!!!!!!
116 5 gallon is $100
Old Nov 24, 2007 | 05:10 PM
RandomName's Avatar
RandomName is infamous around these parts
Can anyone confirm this:
Someone tuner in the other turbo boxster engine arena offers a 91 octane mapping and a southwest (CA, NV, AZ) 91 octane mapping. supposedly the 91 octane offered in this part of the country is actually slightly lower grade than 91 in the rest of the world.
100 octane is almost $8/ gallon in newport beach...
Old Nov 24, 2007 | 05:43 PM
Christian's Avatar
I was told that we could not run leaded, thoughts on this
Christian
Old Nov 24, 2007 | 09:19 PM
Christian's Avatar
A buddy of mine has 110 leaded, it is blue in color. He told me if I mixed it with 93 octane 50/50 split that would make 101.5 octane and that I could run that in my car with my race file, thoughts?
If true, what gains can one expect?
Christian
Old Nov 24, 2007 | 10:02 PM
DMaffo's Avatar
you cant unless you ahve car tuned for it and have your cats and o2 sensors removed...
Old Nov 25, 2007 | 02:28 AM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Isn't there a limit to how far the timing can advance? There's gotta be a point where running higher and higher octane will not advance the timing anymore (maybe 108 or 110 octane)?
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
The Oss
Aug 24, 2015 08:19 PM
